itaps-parallel Question about copies
Tim Tautges tautges at mcs.anl.gov
Wed Jan 13 15:15:20 CST 2010
I think that the statement from the documentation implies that an entity will always have at least one "copy" (maybe
that word is a bit ambiguous).
- tim
Saurabh Tendulkar wrote:
> For functions such as iMeshP_getNumCopies and iMeshP_getCopyParts,
> should the input entity itself be considered in the output?
> The documentation says that "if the given entity is a ghost entity, the
> number of copies will be two (the ghost and its owner)". Extending this
> to non-ghost part boundary entities would suggest that the entity itself
> be included. Is this understanding correct?
> Along those lines, if the entity passed is not a part boundary or ghost
> entity, should iMeshP_getNumCopies return 0 (no other copies) or 1 (the
> entity itself)?
> Thanks,
> saurabh
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
