itaps-parallel Questions about iMeshP
Mark Beall mbeall at simmetrix.com
Wed Dec 23 10:16:31 CST 2009
Karen,
Yes, I'd be interested in attending the phone conference.
mark
On Dec 23, 2009, at 10:21 AM, Devine, Karen D wrote:
> Mark B:
> Thank you for taking the time to organize the entity set functions
> with
> respect to their usefulness with parts.  I should have done such an
> exercise
> when we designed iMeshP.
> For your implementation, starting with just the four functions that
> "make
> sense" is reasonable.  Our group should discuss whether these are,
> indeed,
> the only functions that make sense and if so, whether have part-
> specific
> functions for these four would make the interface more user-friendly.
> Using your email as a starting point, I'll put together a proposal
> and call
> the appropriate phone conference in January for an interface revision
> meeting.  Would you be interested in attending that phone conference?
> Karen
> On 12/21/09 6:25 PM, "Mark Beall" <mbeall at simmetrix.com> wrote:
>> I can give our perspective on an answer to that question. We have a
>> partitioned mesh implementation that is not implemented using entity
>> sets. Thus, the question is which entity set functions would we
>> support in this case. I've broken up the entity set functions below
>> into various groups as described below. The short summary is that our
>> implementation will only support the four functions listed in the
>> initial set. That may, or may not, be considered a woefully
>> incompletely implementation of iMeshP.
>> Entity set functions that make sense (meaning that I need to have
>> this
>> functionality for a part) for an implementation that does not
>> implement parts as entity sets:
>> iMesh_addEntToSet
>> iMesh_rmvEntFromSet
>> iMesh_addEntArrToSet
>> iMesh_rmvEntArrFromSet
>> Entity set functions that I'm not actually sure make sense as
>> fundamental operations on entity sets. Is there any way to implement
>> these that isn't just as efficient as they could be written through
>> an
>> iterator? If not, then it seems they would be better implemented once
>> as a service that builds on the interface (and then could be used
>> with
>> anything that provides an iterator, not just sets).
>> iMesh_subtract
>> iMesh_intersect
>> iMesh_unite
>> Entity set functions have equivalent functionality in iMeshP:
>> iMesh_createEntSet
>> iMesh_destroyEntSet
>> - these sets are not something that the user can create and destroy
>> this way, you create and destroy parts
>> iMesh_isEntContained
>> iMesh_isEntArrContained
>> iMesh_initEntArrIter
>> iMesh_isList
>> - parts are unordered
>> Entity set functions that fundamentally don't make sense for an
>> implementation that doesn't implement parts as entity sets. As I
>> stated in a previous email, it doesn't make sense to enforce the
>> semantics of set containing sets for an implementation that doesn't
>> implement things that way.
>> iMesh_getNumEntSets
>> iMesh_getEntSets
>> iMesh_addEntSet
>> iMesh_rmvEntSet
>> iMesh_isEntSetContained
>> Entity set functions that provide other functionality that I'm unsure
>> of the value with parts. We wouldn't implement these until there
>> was a
>> clear demonstration of value that couldn't be obtained otherwise.
>> iMesh_addPrntChld
>> iMesh_rmvPrntChld
>> iMesh_isChildOf
>> iMesh_getNumChld
>> iMesh_getNumPrnt
>> iMesh_getChldn
>> iMesh_getPrnts
>> iMesh_setEntSetData
>> iMesh_setEntSetIntData
>> iMesh_setEntSetDblData
>> iMesh_setEntSetENData
>> iMesh_getEntSetData
>> iMesh_getEntSetIntData
>> iMesh_getEntSetDblData
>> iMesh_getEntSetEH_data
>> iMesh_getAllEntSetTags
>> iMesh_rmvEntSetTag
>> On Dec 21, 2009, at 2:31 PM, Tim Tautges wrote:
>>> I don't have a problem making parts read-only, though I question
>>> then how one builds partitions.
>>> In terms of duplicating functions in iMesh to specialize for Parts,
>>> if we do that, then I question why we even have an abstraction for
>>> sets, if we're not going to use it for something like this?
>>> At minimum, before even considering adding something like that to
>>> the interface, I'd want to see somebody write up a paragraph
>>> contrasting Parts and entity sets and explaining why distinct things
>>> in the data model are used.  Not for justification to me, but for
>>> explanation to our users, who I'm certain will be asking that
>>> question.  If the choice is so clear, it should be easy to describe
>>> in a short amount of space.
>>> I agree that we need more documentation all around (I've just sent
>>> out the one I wrote on iRel, to a smaller group, but if you're
>>> curious let me know and I'll send a copy).
>>> - tim
>>>> Mark B.:  You are correct that the documentation is confusing.  Our
>>>> hope was
>>>> that an implementation could differentiate between an entity set
>>>> handle and
>>>> a part handle, and react differently based on the handle type.
>>>> Thus,
>>>> overloading some entity set functions to work on parts with part
>>>> handles
>>>> would allow the iMeshP interface to be smaller.  Do you think this
>>>> approach
>>>> is infeasible for at least some of the functions?  You are probably
>>>> correct
>>>> that not all entity set functions make as much sense in the part
>>>> context; we
>>>> can correct the documentation for those.
>>>> All:  What do you think of Mark B's proposal that parts be "read-
>>>> only"
>>>> entity sets and have part-specific add/remove functions?  Also, we
>>>> should go
>>>> through the iMesh interface carefully and determine for which
>>>> functions the
>>>> overloading is appropriate and for which functions it is not.  If
>>>> we now
>>>> agree that the entire approach is infeasible, we should define the
>>>> part
>>>> functions needed to complete iMeshP.
>>>> Karen
>>>> On 12/16/09 9:30 AM, "Mark Beall" <mbeall at simmetrix.com> wrote:
>>>>> In reading things again, there is this bullet above the one I
>>>>> quoted:
>>>>> - Many iMesh functions that accept an iBase_EntitySetHandle are
>>>>> also
>>>>> useful in the context of a iMeshP_PartHandle. These functions are
>>>>> reinterpreted so that they can accept either an
>>>>> or an iMeshP_PartHandle.
>>>>> What, exactly, does this imply? My concern is that it means that a
>>>>> part has to behave as an entity set for a call like
>>>>> iMesh_addEntSet
>>>>> (which adds an entity set to an existing set). The semantics of an
>>>>> entity set say that, if I make this call, the entity set that I
>>>>> added
>>>>> would have to be returned if I subsequently called
>>>>> iMesh_getEntSets on
>>>>> that part.
>>>>> I don't really see how an implementation that doesn't represent
>>>>> parts
>>>>> as entity sets could reasonably be expected to do this.
>>>>> If the intention isn't to require the above to work that way, it
>>>>> would
>>>>> seem that it would be better to say that a part is a "read-only"
>>>>> entity set and that there be part-specific functions to add/remove
>>>>> entities to/from a part. It seems to me that this would allow
>>>>> efficient implementations whether or not they are done using
>>>>> entity
>>>>> sets.
>>>>> mark
>>>>> On Dec 15, 2009, at 4:06 PM, Mark Beall wrote:
>>>>>> On Dec 15, 2009, at 2:14 PM, Tim Tautges wrote:
>>>>>>>>> 4. It is mentioned that a part can act as an entityset. Since
>>>>>>>>> entitysets
>>>>>>>>> can have parent-child and containment relationships with other
>>>>>>>>> entitysets, does this mean that parts need to have them too?
>>>>>>>>> If
>>>>>>>>> so, it
>>>>>>>>> is undefined what this means with respect to the partitioning.
>>>>>>>>> If
>>>>>>>>> not,
>>>>>>>>> what is the expected course of action when a part is used in
>>>>>>>>> an
>>>>>>>>> iMesh
>>>>>>>>> entityset function call which would result in a hierarchical
>>>>>>>>> relationship?
>>>>>>>> The only API requirement is that the functions for querying the
>>>>>>>> contents of
>>>>>>>> sets also work for parts.  Whether or not those functions that
>>>>>>>> *modify* sets
>>>>>>>> (either contents or parent/child links) can be called on a part
>>>>>>>> is
>>>>>>>> implementation-dependent.
>>>>>>> Actually, the v0.8 iMeshP.h states that *all* functions in the
>>>>>>> serial interface taking sets should also work for parts.  So, I
>>>>>>> think that includes things like parent/child relations.  Same
>>>>>>> goes
>>>>>>> for contains relations. I think that does imply the need for a
>>>>>>> recursive getEntities function (which I have in a set of
>>>>>>> extensions
>>>>>>> to iMesh, BTW).
>>>>>> One thing it does say is the following:
>>>>>> - In particular, entities are added to and removed from local
>>>>>> parts
>>>>>> via the same functions that are used to manipulate entity sets.
>>>>>> That
>>>>>> is, given a mesh instance, an entity handle, and a part handle,
>>>>>> the
>>>>>> entity is added to or removed from the part via calls to the
>>>>>> following functions with the part handle passed as the entity set
>>>>>> handle:
>>>>>> - Add entity to part --> iMesh_addEntToSet
>>>>>> - Remove entity from part --> iMesh_rmvEntFromSet
>>>>>> - Add array of entities to part --> iMesh_addEntArrToSet
>>>>>> - Remove array of entities from part --> iMesh_rmvEntArrFromSet
>>>>>> I didn't re-read the entire thing again to see if it says that
>>>>>> all
>>>>>> other functions taking sets should also work for parts.
>>>>>> However, if
>>>>>> that is the case, it would seem that that requires an
>>>>>> implementation
>>>>>> that actually represents parts as entity lists.
>>>>>> mark
>>> "You will keep in perfect peace him whose mind is
>>> steadfast, because he trusts in you."               Isaiah 26:3
>>>            Tim Tautges            Argonne National Laboratory
>>>        (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>>        phone: (608) 263-8485      1500 Engineering Dr.
>>>          fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
