itaps-parallel Questions about iMeshP
Tim Tautges tautges at mcs.anl.gov
Mon Dec 21 10:56:35 CST 2009
Interesting.  I've thought about PIC codes in the context, but always wondered whether apps would consider it overkill
to do the particles with vertices (which I think is what you're implying below?  Or not?)
- tim
Devine, Karen D wrote:
> Thanks, Tim, for providing a good example.  Here's another:  a
> particle-in-cell code can partition the mesh one way for force calculations
> and a different way for particle calculations.  The force calculations use a
> static partitioning; the particle calculations use a dynamic partitioning
> that attempts to maintain particle balance.
> Karen
> On 12/18/09 9:54 AM, "Tim Tautges" <tautges at mcs.anl.gov> wrote:
>> The best example, brought up by both Karen and me IIRC, is of
>> large-deformation transient dynamics with contact, where
>> the FE solution of the dynamics is solved on 3d elements on one partition, and
>> the contact solution is solved on faces
>> on a different partition.  Many believe it was this capability that made truly
>> scalable parallel FEM with contact even
>> possible.  See e.g.
>> Transient dynamics simulations: parallel algorithms for contact detection and
>> smoothed particle hydrodynamics,
>> Proceedings of the 1996 ACM/IEEE conference on Supercomputing, 1996.
>> That's just one reference, there are many others for that particular work.
>> I think the details of multiple *active* partitions still need some work, both
>> in use cases and in how they behave under
>> iMeshP.  Normally I wouldn't advocate such an unexplored thing being part of
>> the initial interface definition, but in
>> this case I think it's an important enough capability that it's justified.
>> - tim
>> Mark Beall wrote:
>>> As a more general context to the questions that Saurabh asked, the main
>>> questions we have about iMeshP are issues related to having multiple
>>> partitions. Although we won't be supporting that for now (since our
>>> software doesn't support that), it would be helpful in understanding
>>> that need if someone could give some examples of how this functionality
>>> would be used.
>>> mark
>> "You will keep in perfect peace him whose mind is
>>    steadfast, because he trusts in you."               Isaiah 26:3
>>               Tim Tautges            Argonne National Laboratory
>>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>           phone: (608) 263-8485      1500 Engineering Dr.
>>             fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
