itaps-parallel Questions about iMeshP
Mark Beall mbeall at simmetrix.com
Fri Dec 18 14:50:13 CST 2009
If someone could email me a paper on that work (or similar work that
has the same needs), I'd appreciate it.
mark
On Dec 18, 2009, at 11:54 AM, Tim Tautges wrote:
> The best example, brought up by both Karen and me IIRC, is of large-
> deformation transient dynamics with contact, where the FE solution
> of the dynamics is solved on 3d elements on one partition, and the
> contact solution is solved on faces on a different partition.  Many
> believe it was this capability that made truly scalable parallel FEM
> with contact even possible.  See e.g.
> Transient dynamics simulations: parallel algorithms for contact
> detection and smoothed particle hydrodynamics,
> Proceedings of the 1996 ACM/IEEE conference on Supercomputing, 1996.
> That's just one reference, there are many others for that particular
> work.
> I think the details of multiple *active* partitions still need some
> work, both in use cases and in how they behave under iMeshP.
> Normally I wouldn't advocate such an unexplored thing being part of
> the initial interface definition, but in this case I think it's an
> important enough capability that it's justified.
> - tim
> Mark Beall wrote:
>> As a more general context to the questions that Saurabh asked, the
>> main questions we have about iMeshP are issues related to having
>> multiple partitions. Although we won't be supporting that for now
>> (since our software doesn't support that), it would be helpful in
>> understanding that need if someone could give some examples of how
>> this functionality would be used.
>> mark
> "You will keep in perfect peace him whose mind is
>  steadfast, because he trusts in you."               Isaiah 26:3
>             Tim Tautges            Argonne National Laboratory
>         (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>         phone: (608) 263-8485      1500 Engineering Dr.
>           fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
