itaps-parallel Questions about iMeshP
Tim Tautges tautges at mcs.anl.gov
Fri Dec 18 10:54:43 CST 2009
The best example, brought up by both Karen and me IIRC, is of large-deformation transient dynamics with contact, where
the FE solution of the dynamics is solved on 3d elements on one partition, and the contact solution is solved on faces
on a different partition.  Many believe it was this capability that made truly scalable parallel FEM with contact even
possible.  See e.g.
Transient dynamics simulations: parallel algorithms for contact detection and smoothed particle hydrodynamics,
Proceedings of the 1996 ACM/IEEE conference on Supercomputing, 1996.
That's just one reference, there are many others for that particular work.
I think the details of multiple *active* partitions still need some work, both in use cases and in how they behave under
iMeshP.  Normally I wouldn't advocate such an unexplored thing being part of the initial interface definition, but in
this case I think it's an important enough capability that it's justified.
- tim
Mark Beall wrote:
> As a more general context to the questions that Saurabh asked, the main
> questions we have about iMeshP are issues related to having multiple
> partitions. Although we won't be supporting that for now (since our
> software doesn't support that), it would be helpful in understanding
> that need if someone could give some examples of how this functionality
> would be used.
> mark
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
