itaps-parallel Questions about iMeshP
Mark Beall
mbeall at simmetrix.com
Tue Dec 15 15:06:12 CST 2009
On Dec 15, 2009, at 2:14 PM, Tim Tautges wrote:
>>> 4. It is mentioned that a part can act as an entityset. Since
>>> entitysets
>>> can have parent-child and containment relationships with other
>>> entitysets, does this mean that parts need to have them too? If
>>> so, it
>>> is undefined what this means with respect to the partitioning. If
>>> not,
>>> what is the expected course of action when a part is used in an
>>> iMesh
>>> entityset function call which would result in a hierarchical
>>> relationship?
>> The only API requirement is that the functions for querying the
>> contents of
>> sets also work for parts. Whether or not those functions that
>> *modify* sets
>> (either contents or parent/child links) can be called on a part is
>> implementation-dependent.
> Actually, the v0.8 iMeshP.h states that *all* functions in the
> serial interface taking sets should also work for parts. So, I
> think that includes things like parent/child relations. Same goes
> for contains relations. I think that does imply the need for a
> recursive getEntities function (which I have in a set of extensions
> to iMesh, BTW).
One thing it does say is the following:
- In particular, entities are added to and removed from local parts
via the same functions that are used to manipulate entity sets. That
is, given a mesh instance, an entity handle, and a part handle, the
entity is added to or removed from the part via calls to the following
functions with the part handle passed as the entity set handle:
- Add entity to part --> iMesh_addEntToSet
- Remove entity from part --> iMesh_rmvEntFromSet
- Add array of entities to part --> iMesh_addEntArrToSet
- Remove array of entities from part --> iMesh_rmvEntArrFromSet
I didn't re-read the entire thing again to see if it says that all
other functions taking sets should also work for parts. However, if
that is the case, it would seem that that requires an implementation
that actually represents parts as entity lists.
mark
More information about the itaps-parallel
