itaps-parallel Questions about iMeshP
Tim Tautges tautges at mcs.anl.gov
Tue Dec 15 13:14:07 CST 2009
Jason Kraftcheck wrote:
> The responses below are my interpretation of these things only.
> Saurabh Tendulkar wrote:
>> Hi,
>> We are trying to implement the iMeshP interface to our software. We have
>> the following questions and are hoping someone could help us with these:
>> 1. What does the mesh instance represent in iMeshP? Is it essentially
>> the on-process subset of entities of some global mesh? Where does the
>> control of the global mesh lie in this case? It does not appear to be
>> with the partition, as there can be multiple partitions of the same mesh.
> What does "control of the global mesh" entail?  What specific functionality
> is missing from the API?  If it isn't an API issue, then put the "control of
> the global mesh" wherever it best fits in your implementation.
I've interpreted the global mesh as a set of mesh instances, one per process, with the collection established by the
application.  The v0.8 iMeshP.h describes the global mesh as being associated with a partition and an MPI communicator,
but that description doesn't allow for multiple active partitions, which in some cases I think will be necessary.
>> 2. It appears that the mesh contains the entities and it is the
>> partition that controls how the entities lie in parts. This seems to
>> mean that an entity can be in the mesh but not in a part (for example,
>> when a part that contains entities is deleted). Is this fundamentally
>> disallowed? Because various aspects of iMeshP are not defined if this is
>> allowed. For example, if the entity was owned by the part that was
>> deleted, who owns the entity now? And, how does one know whether an
>> entity can be deleted from the mesh (next question)?
I think part ownership of entities should only be interpreted in the context of a parallel distribution of mesh, rather
than being something intrinsic to the representation of those entities in an iMeshP instance.  So, an entity can exist
outside a part.  Since we handle modification at a fairly low level in other parts of iMesh, I would expect that if an
application requests deletion of a part, the entities in that part have either been moved to another part or removed
from the partition.
> I think we have to allow for this case, even though it may result in some
> iMeshP calls failing for such entities.  If there are multiple active
> partitions, can we practically require that all entities be in all
> partitions?  Even those of different dimension?  If I have a partition that
> distributes volume elements and a different one that distributes surface
> elements, what part of the volume mesh partition is a surface element in?
>> 3. Who controls the deletion of entities when they are no longer needed
>> on-process - eg. if they are migrated away, especially while keeping in
>> mind that there may be multiple partitions (the entity may be needed on
>> one and not on another).
Yeah, good question.  I don't think anyone's far enough along implementing or using iMeshP to have experience with that.
> I'm not sure about this.  Given that an entity may exist only in some subset
> of the partitions, the two options appear to be: a) the application is
> responsible for deletion or the entity is never deleted or b) the
> implementation does some kind of reference counting such that it can delete
> the entity when it is a member of no partition.
>> 4. It is mentioned that a part can act as an entityset. Since entitysets
>> can have parent-child and containment relationships with other
>> entitysets, does this mean that parts need to have them too? If so, it
>> is undefined what this means with respect to the partitioning. If not,
>> what is the expected course of action when a part is used in an iMesh
>> entityset function call which would result in a hierarchical relationship?
> The only API requirement is that the functions for querying the contents of
> sets also work for parts.  Whether or not those functions that *modify* sets
> (either contents or parent/child links) can be called on a part is
> implementation-dependent.
Actually, the v0.8 iMeshP.h states that *all* functions in the serial interface taking sets should also work for parts.
  So, I think that includes things like parent/child relations.  Same goes for contains relations.  I think that does
imply the need for a recursive getEntities function (which I have in a set of extensions to iMesh, BTW).
- tim
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
