itaps-parallel iMesh interface question...
Mark Miller
miller86 at llnl.gov
Tue Mar 24 23:45:14 CDT 2009
Hi All,
I am seeing a contradiction in documentation here as well as behavior
between implementations regarding the 'has_data' argument here.
The paragraph says...
*has_data!=0 ==> 'next iterator value is the end of iteration'
However, the \param statement says...
*has_data==0 ==> 'next iterator has an entity'
/**\brief Get entity corresponding to an iterator and increment
iterator
* Get the entity corresponding to an array iterator, and increment the
* iterator. Also return whether the next value of the iterator has
* an entity (if non-zero, next iterator value is the end of the
* iteration).
* \param instance iMesh instance handle
* \param entity_iterator Iterator being queried
* \param entity_handle Pointer to an entity handle corresponding to the
* current value of iterator
* \param has_data Pointer to flag; if returned non-zero, next iterator
* has an entity
* \param *err Pointer to error type returned from function
void iMesh_getNextEntIter(iMesh_Instance instance,
/*in*/ iMesh_EntityIterator entity_iterator,
/*out*/ iBase_EntityHandle* entity_handle,
/*out*/ int *has_data,
/*out*/ int *err);
Either way, I find these statements pretty unclear and, in particular,
the name 'has_data' not consistent with at least one of the above
meanings.
So, what does 'has_data' mean here? If I were betting, I think it means
that if after returning from the iMesh_getNextEntIter call,
*has_data==0, it means the returned entity in 'entity_handle' is NOT
valid and the iteration has reached the end.
However, I think I am seeing some difference in behavior between old and
newer implementations of MOAB, at the very least, in this regard. And, I
don't really know what this 'has_data' value means.
Mark C. Miller, Lawrence Livermore National Laboratory
email: mailto:miller86 at llnl.gov
(M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
(Th/F) (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel
