itaps-parallel IGeomP, iRelP?
Mark Shephard
shephard at scorec.rpi.edu
Fri Mar 13 13:08:11 CDT 2009
The CAD models are typically small enough that we have not worried about
distributing them also. If we need to consider distributing the model
there are a number of possible approaches with the one that I would push
being a function of what applications were being supported. For example
I would tend to use different methods for distributing the model in each
of the three cases of doing modeling operations, supporting mesh
generation from the model and supporting mesh adaptation/analysis.
If we think its critical, it is something I can discuss.
Devine, Karen D wrote:
> Mark and Tim (and anyone else who wants to comment):
> In our original ITAPS proposal, we mention partitioning of geometry
> information. We have focused on parallel meshes so far. But what are your
> needs for distributed geometry information and mapping between distributed
> geometries and meshes? How do you handle this information now? What do you
> envision you and your applications people will need going forward?
> Thanks.
> Karen
More information about the itaps-parallel
