itaps-parallel [Fwd: **** iMesh.h and iBase.h changes ****]
Vitus Leung
vjleung at sandia.gov
Mon Jan 5 13:36:11 CST 2009
Lori,
I am traveling the first pair of days.
Vitus
On Mon, 2009-01-05 at 11:54 -0700, Lori A. Diachin wrote:
> Hi All,
> I'd like to check in on the status of everyone's changes wrt to the
> iMesh.h and iBase.h files that Jason sent out back in October. We
> decided to defer these until after SC08 and gave ourselves an internal
> deadline of Dec 15... so, are we done yet? :-)
> Seriously - it was my understanding that folks had agreed in principle
> to all of these changes; the one exception was what to do about item #6
> below. It may very well be that we need a quick telecon to discuss
> this as well as get an update on status. Carl is planning to send out
> the iMesh paper by Jan 23, so we may want to touch base before then..
> when are folks available for a telecon? To narrow it down a bit, please
> send me the times you are not available on Monday/Tuesday Jan 12th and
> 13th, or Tues/Wed the 20th and 21st.
> Thanks,
> Lori
> -------- Original Message --------
> Subject: **** iMesh.h and iBase.h changes ****
> Date: Fri, 24 Oct 2008 18:13:11 -0500
> From: Jason Kraftcheck <kraftche at cae.wisc.edu>
> To: TSTT Interface <tstt-interface at mcs.anl.gov>
> Here is the list of proposed changes to iMesh.h (yes, not just iMeshP.h)
> that were a) agreed upon during the latest telecon and b) may need to be
> completed by all implementations by SC'08. If you object to any of this,
> please speak out soon. I've attached copies of the interface definitions,
> updated as described below.
> 1) Version defines: Beginning with version 0.8 of iMesh.h, we will add the
> following C preprocessor macros. This will allow, going forward,
> applications to be compatible with more than one version of the interface*.
> #define IMESH_MAJOR_VERSION 0
> #define IMESH_MINOR_VERSION 7
> 2) Zero set handle: All mention of passing 'zero' for a set handle in all
> iMesh.h documention should be replaced with the root set handle*.
> Implementations for which a) the root set handle is not zero and b) that
> actually followed the documentation in that they check for zero rather than
> the root set will need to be updated.
> 3) Handle types*: The current handle definitions:
> typedef void* iBase_Instance;
> typedef void* iBase_EntityHandle;
> typedef void* iBase_EntitySetHandle;
> typedef void* iBase_TagHandle;
> typedef void* iMesh_Instance;
> typedef void* iMesh_EntityIterator;
> typedef void* iMesh_EntityArrIterator;
> will be replaced with:
> typedef struct iBase_Instance_Private* iBase_Instance;
> typedef struct iBase_EntityHandle_Private* iBase_EntityHandle;
> typedef struct iBase_EntitySetHandle_Private* iBase_EntitySetHandle;
> typedef struct iBase_TagHandle_Private* iBase_TagHandle;
> typedef struct iMesh_Instance_Private* iMesh_Instance;
> typedef struct iMesh_EntityIterator_Private* iMesh_EntityIterator;
> typedef struct iMesh_EntityArrIterator_Private* iMesh_EntityArrIterator;
> 4) New Function:
> /**\brief Set geometric dimension of vertex coordinates
> * Set the geometric dimension of the mesh. Notes: An application
> * should not expect this function to succeed unless the mesh database
> * is empty (no vertices created, no files read, etc.)
> *\param instance Mesh database from which to request change.
> *\param geom_dim Requested geometric dimension.
> void iMesh_setGeometricDimension( iMesh_Intance instance,
> /*in*/ int geom_dim,
> /*out*/ int* err );
> 5) Changed Functions: There are several functions for which an entity set
> handle is treated as 'inout' where it should be 'in'*. These include:
> iMesh_addEntToSet
> iMesh_rmvEntFromSet
> iMesh_addEntArrToSet
> iMesh_rmvEntArrFromSet
> iMesh_addEntSet
> iMesh_rmvEntSet
> iMesh_addPrntChld
> iMesh_rmvPrntChld
> The argument shoudl be 'in' because the argument (the value of the
> handle) is not changed.
> NOTE: The changes described in 3) will ensure that this change results
> in compile-time errors. Without the changes in 3), changing the real
> type from void** to void* for the arguments would still compile,
> which could be disastrous.
> 6) The following two functions:
> iMesh_getAllVtxCoords
> iMesh_getVtxCoordIndex
> will be replaced with the new function below.
> NOTE: This is slightly different than what was discussed during
> the telecon. I a) noticed a deficiency in the usage (added
> the 'entity_handles' output list) and b) dropped the in_entity_set
> argument, for which no agreement was reached during the telecon.
> /**\brief Get indexed representation of mesh or subset of mesh
> * Given an entity set and optionally a type or topology, return:
> * - The entities in the set of the specified type or topology
> * - The entities adjacent to those entities with a specified
> * type, as a list of unique handles.
> * - For each entity in the first list, the adjacent entities,
> * specified as indices into the second list.
> *\param entity_set_handle The set of entities from which to query
> *\param entity_type_requestor If not iBase_ALL_TYPES, act only on
> * the subset of 'entity_set_handle' of the
> * specified type.
> *\param entity_topology_requestor If not iMesh_ALL_TOPOLOGIES, act only
> * on the subset of 'entity_set_handle' with
> * the specified topology.
> *\param entity_type_requested The type of the adjacent entities to
> * return.
> *\param entity_handles The handles of the (non-struct) subset of
> * the entity set indicated by
> * 'entity_set_handle' and the optional type
> * and topology filtering arguments.
> *\param adj_entity_handles The union of the entities of type
> * 'requested_entity_type' adjacent to each
> * entity in 'entity_handles'.
> *\param adj_entity_indices For each entity in 'entity_handles', the
> * adjacent entities of type
> * 'entity_type_requested', specified as
> * indices into 'adj_entity_handles'. The
> * values are concatenated into a single
> * array in the order of the entity handles
> * in 'entity_handles'.
> *\param offset For each entity in the corresponding
> * position in 'entity_handles', the position
> * in 'adj_entity_indices' at which values
> * for that entity are stored.
> void iMesh_getAdjEntIndices(iMesh_Instance instance,
> /*in*/ const iBase_EntityHandle entity_set_handle,
> /*in*/ const int entity_type_requestor,
> /*in*/ const int entity_topology_requestor,
> /*in*/ const int entity_type_requested,
> /*inout*/ iBase_EntityHandle** entity_handles,
> /*inout*/ int* entity_handles_allocated,
> /*out*/ int* entity_handles_size,
> /*inout*/ iBase_EntityHandle** adj_entity_handles,
> /*inout*/ int* adj_entity_handles_allocated,
> /*out*/ int* adj_entity_handles_size,
> /*inout*/ iBsae_EntityHandle** adj_entity_indices,
> /*inout*/ int* adj_entity_indices_allocated,
> /*out*/ int* adj_entity_indices_size,
> /*inout*/ int** offset,
> /*inout*/ int* offset_allocated,
> /*out*/ int* offset_size,
> /*out*/ int *err);
> The code below uses the old interface to retrieve a copy of a hexahedral
> mesh in a simple array form:
> MBEntityHandle *vertices = 0, *hexes = 0;
> int *hex_vertex_indices = 0, *hex_vertex_offsets = 0;
> double* coords;
> int num_vertices, num_hexes, junk, junk2, junk3, err, order;
> int *junk_array;
> junk = 0;
> iMesh_getEntities( instance, root_set,
> iBase_ALL_TYPES,
> iMesh_HEXAHEDRON,
> &hexes, &junk, &num_hexes, &err );
> junk = 0;
> iBase_VERTEX,
> &vertices, &junk, &num_vertices, &err );
> junk = junk2 = 0;
> junk_array = NULL;
> order = iBase_INTERLEAVED;
> iMesh_getAllVtxCoords( instance, root_set,
> &coords, &junk, &junk,
> &junk_array, &junk2, &junk2,
> &order, &err);
> free(junk_array);
> junk = junk2 = junk3 = 0;
> junk_array = NULL;
> iMesh_getVtxCoordIndex( instance, root_set,
> iBase_ALL_TYPES, iMesh_HEXAHEDRON,
> iBase_VERTEX,
> &hex_vertex_offsets, &junk, &junk,
> &hex_vertex_indices, &junk2, &junk2,
> &junk_array, &junk3, &junk3,
> &err );
> free( junk_array );
> The same code in the new API will be:
> double* coords;
> int num_vertices, num_hexes, junk, junk2, junk3, junk4, err;
> int order;
> junk = junk2 = junk3 = junk4 = 0;
> iMesh_getAdjEntIndices( instance, root_set,
> iBase_VERTEX,
> &vertices, &junk2, &num_vertices,
> &hex_vertex_indices, &junk3, &junk3,
> &hex_vertex_offsets, &junk4, &junk4 );
> junk = 0;
> iMesh_getVtxArrCoords( instance,
> vertices, num_vertex,
> &order,
> &err );
> 7) New Function: Array form of iMesh_isEntContained to replace
> containment flags no longer returned from iMesh_getVtxCoordIndex
> (and hopefully some day all the other functions with a similar
> argument).
> void iMesh_isEntArrContained( iMesh_Instance instance,
> /*in*/ iBase_EntitySetHandle containing_set,
> /*in*/ const iBase_EntityHandle* entity_handles,
> /*in*/ int num_entity_handles,
> /*inout*/ int** is_contained,
> /*inout*/ int* is_contained_allocated,
> /*out*/ int* is_contained_size,
> /*out*/ int* err );
> 8) Replace some iBase_EntityHandle with iBase_EntitySetHandle where
> appropriate*:
> iMesh_getAdjEntities
> - jason
> * Similar changes should probably be made to iGeom.h, iMeshP.h, and iRel.h,
> but that was not discussed during the telecon.
More information about the itaps-parallel
