itaps-parallel archives moved
Tim Tautges tautges at mcs.anl.gov
Wed Oct 22 09:23:13 CDT 2008
Note, I can set this option for people individually, if they still want
duplicate messages.  Just let me know.  I've verified that the default
behavior is no duplicates.
- tim
Jason Kraftcheck wrote:
> Tim Tautges wrote:
>> Hi all,
>>   The itaps-parallel mailing list is now under mailman, which means the
>> archives are being stored in a different place
>> (http://lists.mcs.anl.gov/pipermail/itaps-parallel/).  The older
>> archives will continue to be at
>> http://www-unix.mcs.anl.gov/web-mail-archive/lists/itaps-parallel/maillist.html.
> The mailman bin/arch command can be used to import the old archives into
> mailman (if they're in mbox or some other standard format.)
> - jason
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
