itaps-parallel Re: typedef structure in iMeshP.h
Jason Kraftcheck kraftche at cae.wisc.edu
Tue Oct 21 16:33:44 CDT 2008
Jason Kraftcheck wrote:
> Devine, Karen D wrote:
>> Jason:  Thank you for the explanation.  I agree that distinguishing between
>> handle types is a good idea.  It might be good to use it more broadly --
>> that is, not only in iMeshP.  But if we use it, will it cause problems for
>> the iMesh functions to which we are allowing either a set handle or a part
>> handle to be passed?
> Good point.  I forgot about that.  In that case, the part handle should be
> defined as:
>   typedef iMeshP_EntitySetHandle iMeshP_PartHandle;
> regardless of how iMeshP_EntitySetHandle is defined.
> - jason
s/iMeshP_EntitySetHandle/iBase_EntitySetHandle/
- jason
More information about the itaps-parallel mailing list
