itaps-parallel Re: typedef structure in iMeshP.h
Jason Kraftcheck
kraftche at cae.wisc.edu
Tue Oct 21 14:10:35 CDT 2008
Onkar Sahni wrote:
> I am not trying to argue on number of ways we can do this... but there
> should be discussion and consensus on one way of doing it... and as of now
> I do not like this generic macro ITAPS_DECLARE_HANDLE sitting in iMeshP.h
> (which is applicable to almost all handles in ITAPS interface including
> ones in iBase, iRel, iMesh...).
> If iBase.h is always included (even if a user would only use iGeom) then
> macro can go in there or we can keep it simple as:
> // in iMesh.h
> typedef struct iBase_EntityHandle_Private *iBase_EntityHandle;
> // in iMeshP.h
> typedef struct iMeshP_PartitionHandle_Private *iMeshP_PartitionHandle;
I don't think there's much point in discussing it. If you don't like the
macro, then remove it, or move it, or whatever. I put the macro there, and
as I said in the message you replied to: I have no objection to either of
the changes you describe above (except for the C++-style comments.) (Or
perhaps just wait until there's some consensus on whether or not we want to
make such changes to existing interfaces before worrying about whether or
not we are using and want to use the same macro definition for all header
files.)
- jason
More information about the itaps-parallel
