itaps-parallel Re: typedef structure in iMeshP.h
Jason Kraftcheck kraftche at cae.wisc.edu
Tue Oct 21 13:40:16 CDT 2008
Onkar Sahni wrote:
> As Ting mentioned we will check on email update for changes to svn. We do
> exercise this with repositories of our tools/software (probably you guys
> know it but in case... "View Log" link provides log on changes).
> On handle issue we had discussions as can be seen in the link but there
> was no discussion on how its going to be incorporated in header files.
Other than possibly removing the "ITAPS_DECLARE_HANDLE" macro that you
mention below, what other way is there to incorporate it in the header
files?  Either the declaration is in the header file or it is not.
Presumably all handle types that begin with iMeshP_ belong in iMeshP.h
> Moreover, I do not know if ITAPS_DECLARE_HANDLE goes in iMeshP.h or
> iBase.h or other. If we want to have it this way (ITAPS_DECLARE_HANDLE)
> then I think it doesn't goes in iMeshP.h.
If it is only used in iMeshP.h, then that is where it belongs.  If we wish
to use the same macro in other headers, then perhaps it should be moved to
iBase.h.  On the other hand, perhaps we don't want to export this macro to
applications.  Maybe each header should have its own copy of the macro, and
 "#undef ITAPS_DECLARE_HANDLE" as soon as the necessary handle types are
declared.  Or perhaps we should not use a macro to declare the handle types.
 I don't really care how the definition is written.  I do think that making
the different handle types distinct rather than all of them being 'void*"
improves the interface, regardless of how or where such definitions are written.
- jason
More information about the itaps-parallel mailing list
