itaps-parallel iMeshP_syncPartitionAll, iMeshP_getNumGlobalParts, and communication
Jason Kraftcheck kraftche at cae.wisc.edu
Tue Oct 14 16:07:41 CDT 2008
I've been working on implementing the iMeshP interface for MOAB, and have
encountered a tricky spot to implement:
The intent here appears to be (please correct me if I'm misunderstanding
this) that between creating a partition and parts and calling something like
iMeshP_getNumGlobalParts, the application will call iMeshP_syncPartitionAll.
   While this model works fine for partitions created by the application, it
doesn't work very well for something like reading file containing N
different partitioning of varying coarseness.
The options I can think of for implementing iMeshP_getNumGlobalParts such
that it can handle partitions read from files are:
1) Do global communication for all partitions during file load to cache
    global number of parts for each partition read from file.
2) Require application to associate an an MPI_Comm with any partition (we
    don't have an API for this) and call iMeshP_syncPartitionAll on it
    before expecting to be able to get any global data.
3) Require application it associate an an MPI_Comm with any partition (we
    don't have an API for this) and do the communication in
The first option is unpleasant because it involves doing a bunch of
communication to cache data that may never be used.  The second is rather
convoluted.  The third option really seems like the best one to me.  Why did
we decide that we should not be able to do communication in
iMeshP_getNumGlobalParts?  Do we really expect any application to a) not
call this collectively and b) call it more than once?
thanks,
- jason
More information about the itaps-parallel mailing list
