itaps-parallel Asynchronous functions in parallel interface
Onkar Sahni
osahni at scorec.rpi.edu
Fri Oct 10 14:53:54 CDT 2008
I do not think this is true that "asynchronous calls are really
synchronous", that is irrespective of the (below mentioned) ways it is
handled either by OS-level parts of MPI or mesh-library-level threads (I
do not think any forking is necessary at iMesh level by implementations,
one may choose to do that way but many parallel systems do not allow
forking like IBM BG/L, Cray XT3 and I think its limited on IBM BG/P).
What MPI does and how it interacts with OS should not dictate the way we
provide functionality.
On Jason's proposal, I do not recall discussion on this (I may have missed
it) and I do not really see a reason why two tags (source and destination)
are needed.
We can discuss more details on it via emails but before detailed email
discussions I would instead recommend to schedule a phone conference to
discuss these issues (if others think it is required).
- Onkar
> Hi all,
> Thinking more about Jason's proposal lead me to a really important
> question about our parallel interface. If we're proposing to have
asynchronous functions like iMeshP_migrateEntity which return a request
handle, with the application calling the test or wait functions to test
whether a request has finished, where is the code which is executing
that request running? In the case of MPI, there is presumably some
interaction with the OS, which is acting autonomously to fill buffers,
transfer them to other processors, etc. On large parallel systems
that's handled by the OS-level parts of MPI; on workstations or
> clusters, that's probably done by some other thread or process running
on each node (or asynchronous calls are really synchronous). For imesh,
though, are any of the implementations able to do that kind of forking?
> I know MOAB never will. In that case, I think asynchronous calls to
> iMeshP don't make sense, or they only make sense if they're just
pass-through functions to MPI, in which case they're superfluous. I
think it's down in the implementation where asynchronicity is used. For
example, when exchanging tags of owned entities, that function can
initiate and wait for multiple asynchronous messages. Comments?
> - tim
> ================================================================ "You
will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
