itaps-parallel technical issues in iMeshP.h
Tim Tautges
tautges at mcs.anl.gov
Mon Oct 6 16:22:23 CDT 2008
IMO, the argument should be passed as an "in" argument, consistent with
the dtor function to destroy the imesh instance.
- tim
Devine, Karen D wrote:
> Despite what any of us prefer for deletion and destruction routines, we
> should make iMeshP_destroyPartitionAll's behavior consistent with the rest
> of iMesh. Let me know what's consistent, and that's what we will do.
> Karen
>>>> On 10/3/08 12:20 PM, "Jason Kraftcheck" <kraftche at cae.wisc.edu> wrote:
>>>>>> On 10/2/08 3:46 PM, "Jason Kraftcheck" <kraftche at cae.wisc.edu> wrote:
>>>>>> - Why is 'partition_handle' inout? What is this function returning
>>>>>> a handle to? Some other partition?
>>>>> The partition handle should be set to an invalid value when we destroy the
>>>>> partition.
>>>> Why do we do this for partition handles, and not for any other type of
>>>> handle? E.g.:
>>>> iMesh_deleteEnt
>>>> iMesh_deleteEntArr
>>>> iMesh_destroyTag
>>>> iMesh_destroyEntSet
>>>> iMesh_endEntIter
>>>> iMeshP_destroyPart
>>>> and for that matter:
>>>> free
>>>> delete
>>>> fclose
>>>> etc.
>>> Actually, I would ask why ITAPS doesn't invalidate handles for other types
>>> of deletions (as in the list above). As a user, I'd like to have a handle
>>> invalidated when it is no longer valid, so that I couldn't misuse it later.
>> For that to be useful, it requires the assumption that the application has
>> no more than one copy of the handle in question. And when that is true, it
>> is rather trivial to set the handle to an invalid value after calling the
>> 'destroy' function.
>>> And, yes, I wish "free" set its pointer argument to NULL after freeing
>>> memory. So the true answer to your "why" question is that *I* wrote this
>>> section of iMeshP instead of other ITAPS people. :)
>>> Your example below is good, but in a C environment where users have to
>>> destroyPartition themselves, I think invalidating the handle is a good idea.
>>> In your example, you wouldn't have to send a temporary pointer to
>>> destroyPartition; you would only have to remove the "const" definition.
>> But that's exactly my point: I'd have to modify an unrelated part of my code
>> (the 'const') to use this function for no reason other than so that the
>> function can "invalidate" a variable that is about to be destroyed anyway.
>>> The
>>> call to createPartition modifies the partition handle as well. Wouldn't
>>> your class' constructor have to call createPartition? If not, from where
>>> does the constructor get the partition handle?
>> Does it matter where it comes from? Presumably it comes from some code that
>> does the partitioning, which is a bit to complex to put in a constructor. I
>> can just as easily provide an example where the destructor doesn't destroy
>> the handle:
>> class Partition {
>> public:
>> Partition( iMeshInstance instance, iMeshP_PartitionHandle handle )
>> : myHandle(handle), myiMesh(instance) {}
>> iMeshP_PartitionHandle get_handle() const
>> { return myHandle; }
>> iMeshInstance get_mesh() const
>> { return myiMesh; }
>> private:
>> const iMeshP_PartitionHandle myHandle;
>> const iMeshInstance myiMesh;
>> Now the management of the partition handle is "consistent" in that the
>> constructor does not allocate it and the destructor does not release it.
>> However, how I have to make a copy of the handle in the code that does
>> release the handle because I cannot do something like this:
>> iMeshP_destroyPartitionAll( ptn.get_mesh(), ptn.get_handle(), &err );
>> - jason
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
