itaps-parallel technical issues in iMeshP.h
Onkar Sahni
osahni at scorec.rpi.edu
Sat Oct 4 00:14:37 CDT 2008
> care of releasing them, etc. Something like:
> class Partition {
> public:
> Partition( iMeshInstance instance, iMeshP_PartitionHandle handle )
> : myHandle(handle), myiMesh(instance) {}
> ~Partition() {
> int err;
> iMeshP_destroyPartitionAll(myiMesh, &myHandle, &err );
> private:
> const iMeshP_PartitionHandle myHandle;
> const iMeshInstance myiMesh;
I do not know if iMeshP_destroyPartitionAll() is completely necessary
but above example doesn't make it clear either as I would ask why would
one call iMeshP_destroyPartitionAll() in ~Partition() (destructor) with
no call to iMeshP_destroyPartitionAll() in Partition() (constructor)?
class foo {
public:
foo(int *a) : acopy(a) {}
~foo() { delete [] acopy; }
private:
int *acopy;
int main(int argc, int *argv[]) {
int *a_try = new int;
foo foo1(a_try);
delete a_try;
return 1;
a_try is not allocated in foo() but deleted in ~foo() and its not array.
- Onkar
> class Partition {
> public:
> ~Partition() {
> int err;
> private:
> The above code will not compile as is. I want to declare the
> 'iMeshP_PartitionHandle myHandle' as const because I have no intention of
> changing it during the life of the object, but I cannot do so because
> iMeshP_destroyPartitionAll wants to clear the value when the object is
> destroyed. I could, of course, work around this by making a copy of
> myHandle to pass into iMeshP_destroyPartitionAll, but why force people to
> work around the API. Let the caller worry about clearing stale handle
> values if it wants to.
>>> - Why the "All" in the name? It isn't destroying all partitions,
>>> just the passed one. Presumably in the previous function 'All'
>>> means the 'Mesh', but unless where destroying the Mesh in this
>>> function
>>> it doesn't make sense from a consistency POV either.
>> We used the convention "All" to indicate that all processes must call
>> the
>> function synchronously. In this case, all processes in a partition must
>> agree to destroy the partition at the same time. It would be bad for
>> some
>> processes to think a partition exists while other processes have
>> destroyed
>> it.
> I think that "allDestroyPartition" (subject before verb) would be less
> confusing. But maybe that's just me.
>>> iMeshP_getPartFromPartHandle
>>> iMeshP_getPartFromPartHandlesArr
>>> iMeshP_getPartHandleFromPart
>>> iMeshP_getPartHandlesFromPartsArr
>>> - Should these be iMeshP_getPartIdFromPartHandle(sArr)
>>> and iMeshP_getPartHandleFromPartId(sArr) ?
>> Fine with me; they are probably clearer that way.
>>> void iMeshP_iPushTagsEnt
>>> - If 'entities' is an input, it should be const.
>> Shall do. Are all input values supposed to be const? Or just pointers?
> The pointers should be. It doesn't really matter for other inputs. For a
> pointer, specifying it const means that the calling function cannot change
> the pointed-to data. For non-pointer (and non-reference args in C++)
> declaring the arg as const doesn't provide any meaningful guarantees to
> the
> caller. The args are passed by copy. They cannot be anything but "in",
> regardless of a 'const' designator. If the argument is "in" then the
> caller
> shouldn't change it. The C/C++ convention is to use const as necessary to
> force the "callee can't change it" part, implying the "in" property.
> - jason
More information about the itaps-parallel
