itaps-parallel getVtxCoordIndex
Lori A. Diachin diachin2 at llnl.gov
Mon Sep 29 18:28:22 CDT 2008
Hi All,
I came across an issue with the getVtxCoordIndex function while I was
testing my finite element solver code with the GRUMMP implementation of
iMesh.  In talking it over with Carl, we realized that we had very
different interpretations of what should be returned from the function
and that the documentation was unclear.  So we are pinging the group for
feedback so that we can clarify the documentation and ensure that
implementations are compliant...
In particular, I am attempting to request the vertices associated with
triangular faces and so I set the requested_entity_type to FACE,
requested_entity_topology to TRIANGLE, and entity_adjacency_type to
VERTEX.  I expect to get back 3 indices per face so that the offset
array is set to 0,3,6,...  This is how it's implemented in 'simple
mesh'.  I do not use the entity_adjacency_type argument for much of
anything.
Carl had a different interpretation of the spec.  As he understands it,
getVtkCoordIndex first grabs a bunch of adjacent entities, then makes a
list of the vertex indices for the verts of -those- entities.  So for my
request above, he returns individual vertices as the requested adjacency
type and sets the offset array to 0,1,2,3,....   To get the information
I want, he changes the arguments so that the entity_adjacency_type is
FACE to get faces adjacent to TRIANGLES..
Thoughts on these interpretations?  We need to be sure that the
documentation (user guide and man pages are both vague on this) and
compliance test codes are clear on this.
Lori
More information about the itaps-parallel mailing list
