itaps-parallel /usr/local/itaps on mesh.ep.wisc.edu
Mark Miller miller86 at llnl.gov
Wed Sep 10 19:29:12 CDT 2008
Hi All,
I've been working on getting VisIt RE-installed with support for all
three ITAPS implementations and have a hit a couple of snags...
1. Does not appear to be an FMDB installation in /usr/local/itaps.
   What is there is only the autopack lib for FMDB.
2. -fPIC not used to produce the .a's for MOAB. I need to build
   .so's for VisIt. To do this from .a's for MOAB, those .a's needed
   to have been compiled with position independent code (-fPIC).
   Alternatively, if .so's for MOAB are there, I can use those
   directly.
On Tue, 2008-09-09 at 13:45 -0700, Mark Miller wrote:
> Hi All,
> Ok, yes, I do have all three implementations co-existing in VisIt now.
> And, this email would include a picture (with some ridumentary test
> data) of output from all three implementations being displayed in the
> same VisIt session. However, when I went to save the image I had spent
> several minutes adjusting, VisIt crashed on me :(. But, I've got the
> issues with co-existance of implementations resolved and will install
> those to the bootcamp/SC08 machine tomorrow.
> Mark
> On Tue, 2008-09-09 at 12:32 -0700, Mark Miller wrote:
> > Hi Tim and all,
> > I am pretty close to being able to build a VisIt installation with FMDB,
> > GRUMMP and MOAB implementation plugins co-existing in the same VisIt
> > executable. I have at least made it past the hard part of configuring so
> > that the same plugin source code can be compiled and linked against any
> > number of ITAPS implementations. Assuming I will be able to open and
> > view data using each of the three plugins, my next step will be to get
> > this all installed on the bootcamp/SC08 machine. I think will be able to
> > get that working by tomorrow.
> > Mark
> > On Wed, 2008-09-03 at 12:42 -0500, Tim Tautges wrote:
> > > Hi all,
> > >    For those of you with access to mesh.ep.wisc.edu, I've made a
> > > /usr/local/itaps directory, and an itaps group, and made you all members
> > > of that group.  You're welcome to install tools into that directory that
> > > might be useful to others.  At a minimum, I think any of the tools we
> > > give examples of in the tutorials should be there, including MOAB, FMDB,
> > > visit, Mesquite, and maybe Frontier.  I've installed MOABser and MOABpar
> > > there already (serial and parallel versions, resp.).
> > > - tim
Mark C. Miller, Lawrence Livermore National Laboratory
email: mailto:miller86 at llnl.gov
(M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
(Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel mailing list
