itaps-parallel ITAPS for 2D meshes
Tim Tautges tautges at mcs.anl.gov
Tue Sep 2 14:24:24 CDT 2008
Answering Karen's question, yes, these should be types, not dimensions,
though for most I think the two are synonymous.
Regarding multiple dimensions, we could allow multiple ghost dimensions,
or we could say that subsequent calls build on the existing bridge
interactions if they're not reset.
- tim
Mark Shephard wrote:
> They are faces bounded by edges and vertices.
> Note that we solve non-manifold problems where the "elements" (the
> entities that have to be partitioned) can be combinations of regions,
> faces, etc. In addition, we have reasons (defined by the analysis
> procedures) where small groups of elements need to be kept together (be
> a single object to the partitioning process).
> This is why from the beginning I stated I liked to not have a one-to-one
> correspondence between a single mesh entity type and objects to be
> partitioned (something it is my understanding the abstractions of Zoltan
> supports).
> Mark
> Devine, Karen D wrote:
>> In 2D meshes (e.g., triangular or quadrilateral elements), what is the
>> entity type for an element?  Is it a region?  Or must regions be 3D?
>> Here's the reason I ask.  The function iMeshP_createGhostEnts takes as
>> integer arguments a ghost dimension and bridge dimension.  At first, I
>> thought of these arguments as entity types, e.g., regions and faces.  But
>> when I started to draw my 2D picture for the SC08 slides, I realized that
>> what I thought of as regions were actually 2D....so what should the ghost
>> dimension be?
>> Would the ghost function be clearer taking entity types rather than
>> numeric
>> dimensions?
>> Thanks.
>> Karen
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
