itaps-parallel A question about iMeshP interface functions
txie at scorec.rpi.edu txie at scorec.rpi.edu
Mon Aug 18 14:15:36 CDT 2008
Hi, Vitus,
Thanks for using FMDB.
Currently you can download the latest version of FMDB from our website
through anonymous access with the following command:
svn checkout https://gforge.scorec.rpi.edu/svn/fmdb/trunk  YOUR_FMDB_DIR
Please let me know if you have any problems about FMDB. Thanks.
Ting
> Ting,
> I am ready to start converting the Zoltan interface to iMeshP for FMDB.
> How do I get a copy of the code?  I tried to update my copy of FMDB, and
> it did not work.  I do not recall if I actually checked out the code
> before or got a copy some other way.
> Vitus
> On Wed, 2008-08-13 at 13:47 -0600, txie at scorec.rpi.edu wrote:
>> Dear all,
>> I have a question about the design of some iMeshP Entity interface
>> functions. This question is relative to the real execution performance.
>> Some iMeshP Entity interface functions provide two input arguments:
>> entity_handle and partition_handle. The specification requires that one
>> function returns an error code if an entity is not in the partition. But
>> the question is how to decide whether an entity is in the partition
>> since
>> entity_handle (iBase_EntityHandle) may be not globally unique in the
>> partition.
>> I can think of one way in FMDB implementation:
>>  * Get all the local_part_handles in the partition,
>>  * Then get the mesh within each local part,
>>  * Iterate all mesh entities of all dimensions in each part mesh,
>>  * Check if the given entity_handle equals any mesh entity. If yes,
>> entity_handle is valid and local. Otherwise, it is not valid.
>> But this way is not time efficient in the real performance.
>> Please let me know if I make any mistakes or you have any problems about
>> this question. Thanks.
>> Regards,
>> Ting
More information about the itaps-parallel mailing list
