itaps-parallel A question about iMeshP interface functions
Carl Ollivier-Gooch
cfog at mech.ubc.ca
Thu Aug 14 10:35:55 CDT 2008
Onkar Sahni wrote:
>> I had assumed that if one had a handle for an entity at all, that the
>> local
>> processor knew enough about that entity to answer such questions (e.g.
>> that
>> it is an interface or ghost entity.) But I missed several discussions.
>> Are
>> we back to considering entity handles to be globally unique across all
>> processors?
> If entity-handle is local (on local part/proc.) then one can ask such
> questions (ghost entity etc.), but if entity is not local, i.e,
> remote-handle or remote-copt then it is not valid to ask such questions.
> How do we return reasonable error message/code in this case of
> remote-handle. There are no globally unique entity handles.
I'm a bit confused about what the problem is here.
First, I agree that we're certain to be looking at a local entity handle
here (though it could be a ghost or copy). There's simply no way to
pass a remote entity handle --- that would require both a handle and a
part ID.
Second, because a partition is a covering of the entire contents of a
parallel mesh, checking whether an entity is in a partition reduces to
checking whether the entity handle is valid in the local root set, a
test that iMesh requires routinely.
>> It seems to me that the iMeshP_getEntOwnerPart and
>> iMeshP_getEntOwnerPartArr
>> are inherently expensive, and those are the only two for which I see a
>> requirement to return an error if the passed entity is not contained in
>> the
>> partition. I'm looking at the draft spec Karen sent on July 24th. Is
>> there
>> a more recent one?
> I do not see why these will be expensive, at least they are not in FMDB
> implementation.
If those are cheap, then surely checking for partition membership is too
(if it belongs to a part, the entity surely belongs to the partition...).
Maybe I'm being incredibly naive here, but I don't see this as being
terribly difficult or time consuming. Am I missing something here?
Carl
Dr. Carl Ollivier-Gooch, P.Eng. Voice: +1-604-822-1854
Associate Professor Fax: +1-604-822-2403
Department of Mechanical Engineering email: cfog at mech.ubc.ca
University of British Columbia http://www.mech.ubc.ca/~cfog
Vancouver, BC V6T 1Z4 http://tetra.mech.ubc.ca/ANSLab/
More information about the itaps-parallel
