itaps-parallel A question about iMeshP interface functions
Onkar Sahni
osahni at scorec.rpi.edu
Thu Aug 14 10:25:02 CDT 2008
> What is a "remote handle"? And are you talking about entity handles or
> part handles?
remote-entity-handle/remote-entity-copy.
> Presumably if you have some structure that allows for a fast search for
> the
> parts an entity is contained in, then that structure is fairly large, as
> it
> must contain values for every mesh entity. It is either costly in terms
> of
> memory required or slow. Either way, it is expensive.
> How can the FMDB implementation efficiently search for the part an entity
> is
> contained in while not being able to efficiently determine if the entity
> is
> part of a given partition? Is it the cost of determining which partition
> a
> part is in that FMDB cannot do efficiently?
Concern is search in local mesh on processor. FMDB keeps information at
entity level based on its classification to partition-model.
- Onkar
More information about the itaps-parallel
