itaps-parallel Part handles
Tim Tautges
tautges at mcs.anl.gov
Mon Jun 23 10:06:29 CDT 2008
Carl Ollivier-Gooch wrote:
> (As an aside, are the huge parallel machines
> 32 bit or 64?)
32 bit, at least for the near future. The trend seems to be toward
constant-size or slowly increasing size memory on compute nodes and more
cores per node, at least on the IBM BG side (not sure about Cray in the
longer term). I think that will only change as codes start to do more
shared memory on nodes overall, and even then maybe not. Going to 64
bit does increase the size of things, and on machines with only 512MB
per core that can matter.
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
