itaps-parallel Confusion between BOUNDARY, INTERNAL, GHOST
Onkar Sahni osahni at scorec.rpi.edu
Thu Jun 5 10:37:21 CDT 2008
I think BOUNDARY is inter-part boundary (no process involved) and both
iMeshP_getEntStatus() and iMeshP_getEntStatusArr() takes input as
"iMeshP_PartHandle part_handle", see below:
void iMeshP_getEntStatus(iMesh_Instance instance,
                    /*in*/ const iMeshP_PartHandle part_handle,
                    /*in*/ const iBase_EntityHandle entity_handle,
                   /*out*/ int* par_status, //
                   int *err);
- Onkar
> Hi all,
>    I'm in the process of implementing at least part of this interface,
> and I think there's ambiguity about what BOUNDARY, INTERNAL, and GHOST
> really mean.  Namely, are these referring to processor sharing, or the
> relation to the skin?  That is, if an entity is on the skin of a part
> but not shared with another processor, is its status INTERNAL?  If so,
> then I think these values are mutually exclusive, which I think is an
> important requirement if the status is accessed with a single function.
> - tim
> "You will keep in perfect peace him whose mind is
>    steadfast, because he trusts in you."               Isaiah 26:3
>               Tim Tautges            Argonne National Laboratory
>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>           phone: (608) 263-8485      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
