itaps-parallel Proposed tag communication functions
Onkar Sahni
osahni at scorec.rpi.edu
Sat Mar 8 16:36:12 CST 2008
Here are my initial comments on proposed tag communication functions:
prefix_IExchTags and prefixIExchTagsEnt - seems like a send and there is
no equivalent (or counter-part) recv. I think we agreed on 'to_part' to be
replaceable by 'ALL_PART_NGBRS' (note shared entities will be on different
set of parts contained in 'ALL_PART_NGBRS' of local-part).
prefix_ExchTags and prefix_ExchTagsEnt - if they are synchronous call then
I would recommend to use names prefix_SExchTags and prefix_SExchTagsEnt as
used in MPI (In MPI the communication mode is indicated by a one letter
prefix: B for buffered, S for synchronous, and R for ready, so MPI_Send
may complete before a matching receive is posted). Same as above hold in
this case, there is no equivalent (or counter-part) recv.
prefix_WaitEnt - I am not sure if we need this. I think status object (in
prefix_Wait and prefix_WaitAny) should be enough.
- Onkar
> Hi all,
> Here they are. Note that I've added MPI-like request objects to use
> with asynchronous comm'n, and functions to test/wait on these requests,
> much like MPI has. These functions should also be useful with ghost
> communication.
> - tim
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
