itaps-parallel Micro-migration update
Carl Ollivier-Gooch cfog at mech.ubc.ca
Thu Mar 6 11:10:37 CST 2008
Tim Tautges wrote:
> Ok, so I'm still mulling over how to express exchanging tag data between
> parts, and in doing so I've gone back and reviewed Carl's email below.
> In thinking about migration, the following occurs to me:
> 1. We already need the ability to send ghost entities between parts, and
> I'd argue the ability to remove ghost entities on a part
> 2. We should have the ability for an application to change the ownership
> of a given entity (at least, when it's shared between the before and
> after owning parts)
> So, why not implement migration out of its constituent parts, e.g. first
> create ghosts on the destination processor, then change the ownership?
Tim, I think your question is motivated by thinking about the push
migration, right?  In that scenario, I can see doing two calls as suggest:
1.  Push this entity as a ghost (A: sends to B; B: confirms local handle
to A)
2.  Push ownership to B (A: sends ownership to B)
That's one message more than you'd get with a push migration, but maybe
that's okay, especially in bulk.  So maybe for things like load balance
/ re-partition this is a reasonable choice (though I'm pretty sure it'll
be slower and I -think- it actually increases the number of functions in
the interface...  ghosting and migration can be distinguished by a flag...)
But in any case, I see the most common scenario for micro-migration as
being a pull:  a process wants to operate on something it owns but needs
to own a star around it as well.  In this scenario, if you don't already
-have- the ghost, you don't know what to request, so the process would
look something like:
1.  Request a ghost star (A: sends to B; B: sends data; A: confirms
local handles to B)
2.  Request ownership change (A: requests; B: confirms (necessary in
case some other part beats A to it...)).
Whether or not you agree that my outline is capable of handling complex
scenarios, I don't see how the two-request version is going to be
competitive with the one-request version for pull-migration.  So the
syntax I propose below doesn't include this.
Note:  I haven't tried to come up with good, compact names at this
point, nor am I yet proposing syntax for array versions.
A.  Request in-migration of an entity (this is a pull migration).  This
entity must be on the part bdry and is identified by local handle, and
the implementation handles the rest.  If include_upward_adj is true,
then stuff on the remote part also gets migrates (-all-
higher-dimensional entities).  This operation will require multiple
rounds of communication, and at some times certain entities may be
locked (unavailable for local modification) while info about their
remote copies is still in question.
void prefix_migrateEntity(iMesh_Instance instance,
			  const prefix_PartitionHandle partition_handle,
		          const entity_handle local_entity_handle,
		          bool include_upward_adj, int *err);
B.  Update vertex coordinates.  One could argue that we could overload
the setVtxCoords function to do this, and maybe we should.  But that
obfuscates when communication could occur.  The communication here is
push-and-forget.
void prefix_updateVtxCoords(iMesh_Instance instance,
		            const entity_handle local_vertex_handle,
			    int *err);
C.  Poll for messages.  The internals of this function are going to have
to cover a lot of ground.  The array in the return is there as a
placeholder to tell the application that something interesting / useful
has been done to a handle.  This might indicate successful in-migration,
a recent change in vertex location, or successful completion of handle
matching.
void prefix_pollForRequests(iMesh_Instance instance,
		            entity_handle **handles_available,
			    int *handles_allocated,
			    int *handles_size,
			    int *err);
D.  Done with micro-migration.  This is a blocking call, to get
everything up-to-date and back in synch.  Essentially, waits for all
message traffic to clear, as well as (possibly) rebuilding a bunch of
ghost info that was allowed to go obsolete.
void prefix_synchParts(iMesh_Instance instance,
		       int *err);
E.  Replace entities.  This refers to changes on the part bdry where the
application/service is responsible for ensuring that things are done
identically on both sides and that the args are passed in an order that
can be matched.  (Specifically, matching new entities should appear in
the same order in the call array.)  Communication here could be a
two-way push-and-forget, or some variant on push-and-confirm.
void prefix_replaceOnPartBdry(iMesh_Instance instance,
		       const entity_handle *old_entities,
		       const int old_entities_size,
		       const entity_handle *new_entities,
		       const int new_entities_size,
		       int *err);
F.  As Tim suggests, the ability to create and delete ghosts is likely
to be useful, even though for common topologically-based cases, ghost
maintainence can (and IMO should) be handled automagically, either at
migration time or during prefix_synchParts.  Communication here is
push-and-confirm for creation (so that the original knows ID's of the
ghosts), push-and-forget for deletion.  I'm assuming here that the
closure of a new ghost will be pushed automatically as part of the
underlying communication, and that the remote part will clean up the
closure as appropriate during deletion.  Finally, note that createGhost
could easily be tweaked to handle a micro-push migration: change the
name and add a flag.
void prefix_createGhost(iMesh_Instance instance,
		       const prefix_PartHandle target_part,
		       const entity_handle ghost_to_push,
		       int *err);
void prefix_deleteGhostOf(iMesh_Instance instance,
		       const entity_handle ghost_to_purge,
		       int *err);
I think that'll do for now.  At least we've got a starting point for
iteration. :-)
Carl
Dr. Carl Ollivier-Gooch, P.Eng.                   Voice: +1-604-822-1854
Associate Professor                                 Fax: +1-604-822-2403
Department of Mechanical Engineering             email: cfog at mech.ubc.ca
University of British Columbia              http://www.mech.ubc.ca/~cfog
Vancouver, BC  V6T 1Z4                  http://tetra.mech.ubc.ca/ANSLab/
More information about the itaps-parallel mailing list
