itaps-parallel Notes from 3/3/08 phone conference
txie at scorec.rpi.edu
Thu Mar 6 09:55:38 CST 2008
Hi All,
The attached is our proposed non-collective migration functions based on
the 5 needs from Karen's last email. Currently, we have some questions
about the 5 functions listed below (I also put them in the attached file).
Please let us know if you have any problems. Thanks.
Ting
First, do we need functions of array versions for Need 1, 2 and 5?
> Non-collective communication needed:
> 1. Requests to migrate remote entities and (optionally) their
> higher-order
> adjacencies. Note that the iMesh implementation must be smart enough to
> change ownership of lower-order entities that become orphaned due to
> migration.
We don't use argument include_upward_adj, because we think that we only
migrate all (partition) objects around the lower-order mesh entity that is
on the part boundary.
> 2. Push entity data from owner to other parts for migrating entities and
> updating remote copies.
Here, the term 'remote copies' can be modified to 'ghost entities'.
> 5. Capability to replace an entity with new entities, both locally and
> remotely. This capability would include requests to perform an operation
> on
> an entity copy (e.g., split that edge), as well as communication to update
> remote entity handles for the new entities created.
Do we need to specify an argument 'int Replace_OP' in this function?
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/itaps-parallel/attachments/20080306/c9bdb05e/attachment.obj>
More information about the itaps-parallel
