itaps-parallel FMDB migration pseudo code
txie at scorec.rpi.edu txie at scorec.rpi.edu
Wed Feb 27 12:10:14 CST 2008
Dear All,
I have modified the document I sent last time with some simple
descriptions on the communications during FMDB mesh migration.
There are 6 steps in the migration algorithm, and 5 steps of them are
involved with communications between parts. Please refer to the attached
file for the descriptions.
Please let we know if you have any problems. Thanks.
Ting
>>> >> Onkar Sahni wrote:
>>> >>> The document Ting sent few days ago provides details of mesh
>>> migration
>>> >>> code, specifically how it is done in FMDB. With this document I
>>> would
>>> >>> like
>>> >>> to mention one important point.
>>> >>> It is critical to realize that one set/pair of send and recv. is
>>> not
>>> >>> sufficient to keep mesh-database up to date as mesh migration is
>>> done
>>> >>> (whether for partitioning and/or for local mesh modifications).
>>> >>> Basically
>>> >>> to keep track of remote copies (independent of issue whether owner
>>> knows
>>> >>> all remote-copies or all remote-copies know all other
>>> remote-copies),
>>> >>> one
>>> >>> set/pair of send and recv. is not sufficient. Hence,
>>> >>> prefix_sendEntArrToPartsPar and prefix_recvEntArrToPartsPar will
>>> not
>>> be
>>> >>> sufficient.
>>> >>> So we will have to re-visit these functions (as I remember the
>>> >>> impression
>>> >>> was that these would be enough for mesh migration for
>>> mesh-partitioning
>>> >>> and NOT mesh-modifications, where Carl and I are trying to resolve
>>> >>> issues
>>> >>> with the latter (mesh-modification) one).
>>> >>> Please let me know if you have questions.
>>> >>> - Onkar
>>> >>>> Dear All,
>>> >>>> The attached is the pseudo code of current FMDB migration
>>> algorithm
>>> and
>>> >>>> some simple explanations. Please let me know if you have any
>>> problems.
>>> >>>> Thanks.
>>> >>>> Regards,
>>> >>>> Ting
>>> >> "You will keep in perfect peace him whose mind is
>>> >>    steadfast, because he trusts in you."               Isaiah 26:3
>>> >>               Tim Tautges            Argonne National Laboratory
>>> >>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>> >>           phone: (608) 263-8485      1500 Engineering Dr.
>>> >>             fax: (608) 263-4499      Madison, WI 53706
Type: application/pdf
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/itaps-parallel/attachments/20080227/d8c12977/attachment.pdf>
More information about the itaps-parallel mailing list
