itaps-parallel Neighbor definition
Mark Miller
miller86 at llnl.gov
Wed Feb 6 16:37:44 CST 2008
Hi Tim,
This is very clear to me and I agree with it. But, since some of the
discussion after Lori left the conversation is missing, I'd like to take
a stab at adding that here simply in order to take a snapshot of the
history of this discussion...
We basically went full circle in our discussion. The conversation
started with the notion that part neighbors are based upon the sharing
of mesh entities. An objection was raised because we can
often think of circumstances in which two parts need to exchange
data across the 'boundary' between them even when they DO NOT
necessarily share mesh entities. Rercusive Coordinate Bisection and
Finite Volume computations were raised as two examples. In the
former, RCB, I believe we also made arguments that there does in
fact exist a 'shared mesh entity' analog in that there are mesh edges
that are 'cut' by the RCB algorithm and it is those edges that wind
up being 'shared' between parts [I did not consider this yesterday
but what if such edges are never actually instantiated in iMesh?
Would this make the argument theoretically correct but practically
speaking not implementable?]
We observed that there are likely to be many situations in which
processors (or the parts they own) need to communicate that have
nothing to do with underlying mesh topology. So the question arose,
do we expect our Part/Partition model and implementation to support
a more general notion of 'neighbor' or one that is specific to
mesh topology. Ultimately, we argeed on the latter.
We also argued that a notion of neighbor based solely on mesh
topology is a 'sufficient bootstrap' to enable applications requiring a
more general notion of 'neighbor' to affect their communication
patterns. [As an aside, I don't think we considered this argument
in great detail and I wonder if it is in fact true in all cases that
more general notions of neighbor can always be derived from the
topologically specific one being proposed here. I'm inclined NOT to
believe that. At the same time, I think it is also arguable that such
situations are too 'application specific' to be worried about
explicitly supporting in the Part/Parition model we are developing.]
We also agreed that our intention in developing the Part/Partition
model on top of iMesh is to support the topologically common
operations most applications will need and not necessarily ALL
possible communication patterns applications might use.
One question we need to re-visit is what are the implications
(storage and/or performance), if neighbor relationships other than
those determined by topology, are not supported?
Tim Tautges wrote:
> A question arose in yesterday's telecon on what constitutes a part
> neighbor. After some discussion, we came up with the following
> definition and rationale.
> Def: for a given part, a part neighbor of dimension d is any other part
> which shares mesh entities of dimension d with that part (i.e. the
> entity is represented on both parts).
> Rationale:
> - it is desirable to tie the definition of a part neighbor with
> information intrinsic to the mesh, i.e. one could derive information
> about part neighbors using only information about the mesh entities and
> the partition of entities over processors
> - in general, applications will have other criteria determining which
> other processors a given processor communicates with; that information
> can be stored in iMesh using sets and tags already, and applications
> will presumably be able to pass those things to communication functions
> in the itaps parallel interface (thus driving the application-specific
> communication patterns)
> Question: are ghosted/copied entities between parts considered shared?
> I would assert that ghosting/copying should be between processors, not
> parts, so this question is not relevant with respect to part neighbors.
> - tim
> "You will keep in perfect peace him whose mind is
> steadfast, because he trusts in you." Isaiah 26:3
> Tim Tautges Argonne National Laboratory
> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
> phone: (608) 263-8485 1500 Engineering Dr.
> fax: (608) 263-4499 Madison, WI 53706
Mark C. Miller, Lawrence Livermore National Laboratory
email: mailto:miller86 at llnl.gov
(M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
(Th/F) (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel
