itaps-parallel Neighbor definition
Tim Tautges
tautges at mcs.anl.gov
Wed Feb 6 15:31:34 CST 2008
A question arose in yesterday's telecon on what constitutes a part
neighbor. After some discussion, we came up with the following
definition and rationale.
Def: for a given part, a part neighbor of dimension d is any other part
which shares mesh entities of dimension d with that part (i.e. the
entity is represented on both parts).
Rationale:
- it is desirable to tie the definition of a part neighbor with
information intrinsic to the mesh, i.e. one could derive information
about part neighbors using only information about the mesh entities and
the partition of entities over processors
- in general, applications will have other criteria determining which
other processors a given processor communicates with; that information
can be stored in iMesh using sets and tags already, and applications
will presumably be able to pass those things to communication functions
in the itaps parallel interface (thus driving the application-specific
communication patterns)
Question: are ghosted/copied entities between parts considered shared?
I would assert that ghosting/copying should be between processors, not
parts, so this question is not relevant with respect to part neighbors.
- tim
steadfast, because he trusts in you." Isaiah 26:3
Tim Tautges Argonne National Laboratory
(tautges at mcs.anl.gov) (telecommuting from UW-Madison)
phone: (608) 263-8485 1500 Engineering Dr.
fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
