itaps-parallel Assignments for parallel interface, due before 2/5 phone conf
Onkar Sahni
osahni at scorec.rpi.edu
Mon Feb 4 21:09:47 CST 2008
Lori,
I have tried to answer some of your specific queries, see below.
I am still trying to work on my overall comments and concerns (which too
will now have many overlapping inputs).
> - I found the difference between partition handles and partition IDs,
> and when you would use which one, to be very confusing and non
> intuitive. Do we really truly need both, or can we just go with part IDs?
I think a comment will be useful to clarify (as Karen, Carl... agree)
that part IDs are mainly needed to refer to remote parts like if we want
to migrate entities from a part to another part then another part is
described in terms of 'part ID' (i.e., destination_part_id). We need
part-handles, that can be pointers and are local to a process, at least
in serial iMesh functions (in place of entity-set-handle); and also for
other things.
> - the prefix_getNumParts and prefix_getParts seems to duplicate the
> functionality just above it in the file if you just add a myrank, so I
> suggest eliminating these two functions. Speaking of the functions just
> above (getNumPartIds and getNumPartIdsArr) - not really sure why you
> bring "Ids" into the function name other than to avoid conflict with the
> function below which I suggest eliminating)
Ones with rank can provide info. for any rank (off-process) and
moreover, prefix_getParts provide local on-process part-handles (that
can be further used in serial iMesh functions). I do not remember why we
need getNumPartIds and getnumPartIdsArr. If possible we should avoid
them.
> - prefix_sendEntArrToParts and the corresponding receive function both
> appear to take an entityset handle - I would have expected they take an
> entityhandle... is this a typo, or am I missing something?
Yes, infact we do not require part handle(s) (Vitus too proposed these
syntax corrections). And in receive I think 'target' should refer as
'source'.
> - I struggle with the copyEntOnPart functions... I don't fully
> understand what this adds to the interface and I think it could lead to
> headaches when thinking about consistency of information across
> processors.
Remote copy information is very critical in all of RPI's applications.
These functionalities provide link for shared entities. getCopyEntOnPart
is same as getCopiesEnt but only for a specific part. If names are
confusing then I think some re-naming might be required like changing
getCopyEntOnPart to getEntCopyOnAPart. I think providing appropriate
documentation and code-examples may avoid difficulties in thinking about
them.
> - Seems as though the addCopyEnt and removeCopyEnt could be combined
> with the other add functions (that are like entityset functions) with an
> appropriate enumerator (e.g. OWNED, COPY, etc)..
No this is not the case. I want to also clarify that addCopyEnt can be
called many times for a particular entity on a specific part (in case
where we want to add multiple remote copies for a particular entity on a
specific part, we may also want to provide add/rmvCopies).
Please let me know if something is not clear.
- Onkar
> Lori
> Devine, Karen D wrote:
>> In the last phone conf, someone suggested that we put together a draft
>> of
>> the syntax for the capabilities on which we agreed. So I added syntax
>> from
>> Carl's, Onkar's and Tim's past emails to our Combined document. For
>> readability, I turned the file into a C header file; the discussions
>> from
>> the Combined document are now comments in the C file. The file is
>> attached.
>> For now, I'd rather not discuss:
>> - values of "prefix_".
>> - my use of "//" for comments being non-standard for some C compilers.
>> - my inconsistent use of "const" (unless I used it for a return
>> argument --
>> oops!)
>> - whether or not this file would actually compile.
>> Here are your assignments:
>> ALL: Please give your opinions of the questions below. Some are simple
>> questions resulting from the fact that I'm not used to ITAPS code
>> conventions.
>> Mark M. and Lori:
>> - Review all functions at a high level to identify gaps and
>> duplications in
>> capability. Suggest functions that should be added or removed.
>> - Review all functions at a high level to determine whether our syntax
>> is
>> generally consistent with ITAPS' conventions and generally consistent
>> within
>> the document. You shouldn't catch every detail; just let us know
>> whether
>> someone who is comfortable with other ITAPS interfaces would find this
>> interface comfortable as well.
>> Mark M and Onkar:
>> - Review all functions at a high level and indicate whether their use
>> of
>> communication will be definite, likely, or nonexistent. If they incur
>> communication, will the communication be global (e.g., MPI_Allreduce) or
>> point-to-point (e.g., MPI_Send/MPI_Recv)? We'll eventually modify the
>> function names to indicate whether or not they incur communication.
>> Onkar:
>> - Review in detail the Entity Functionality section. This section has
>> the
>> entity copying capability, including the add/remove copies that you
>> discussed in the last phone conf.
>> Vitus:
>> - Propose the communication functions needed to support
>> prefix_sendEntArrToParts and prefix_receiveEntArrToParts.
>> Carl:
>> - Should functions prefix_getEntSets and prefix_getNumEntSets be added
>> to
>> Carl's sixteen functions? They appear to be analogous to
>> prefix_getEntities and prefix_getNumOfType.
>> - Review in detail the Part Functionality section.
>> Tim:
>> - Review in detail the Partition Functionality section.
>> Questions for everyone:
>> - When we specify a part handle, must we always also specify a
>> partition
>> handle? That is, should a part be uniquely identified by the pair
>> (partition_handle, part_handle), just as entities are uniquely
>> identified by
>> (mesh_instance, entity_handle)? "No" is the most convenient answer to
>> this
>> question; if parts are uniquely identified by only the part handle, we
>> can
>> do the entity-set argument overloading that we discussed at bootcamp.
>> We
>> can also remove the partition_handle argument from many of the
>> functions. I
>> had previously argued for use of the tuple, but many things would be
>> easier
>> if we didn't need it. Can all the implementations generate part handles
>> that are unique within an iMesh_Instance, rather than within a
>> partition?
>> - With iterators over parts or part boundaries, is it necessary to have
>> separate interface functions for getNext, reset, and end, or will the
>> standard iMesh functions for getNext, reset, and end suffice? That is,
>> once
>> an iterator is initiated, do we need to continue passing the part handle
>> and, perhaps, neighbor-part id, to the iterator, or can the iterator
>> "remember" these just as it remembers entity type and topology? If we
>> can
>> re-use the iMesh getNext, reset and end, we can remove six functions
>> from
>> Carl's sixteen functions, bringing the count back to his original
>> estimate
>> of ten.
>> - Which functions should operate on single parts and/or entities, and
>> which
>> should have array versions (function_name and function_nameArr)? I
>> included
>> both wherever we had a comment "Need single-part and array-part
>> versions" in
>> the combined document, but I won't be offended if we remove some of the
>> functions.
>> - Since global IDs for entities are not used anywhere in the interface,
>> I
>> propose their generation and use should be a service on top of the
>> interface
>> rather than part of the interface. What say you?
More information about the itaps-parallel
