itaps-parallel Assignments for parallel interface, due before 2/5 phone conf
Devine, Karen D kddevin at sandia.gov
Tue Jan 22 12:48:55 CST 2008
In the last phone conf, someone suggested that we put together a draft of
the syntax for the capabilities on which we agreed.  So I added syntax from
Carl's, Onkar's and Tim's past emails to our Combined document.  For
readability, I turned the file into a C header file; the discussions from
the Combined document are now comments in the C file.  The file is attached.
For now, I'd rather not discuss:
-  values of "prefix_".
-  my use of "//" for comments being non-standard for some C compilers.
-  my inconsistent use of "const" (unless I used it for a return argument --
oops!)
-  whether or not this file would actually compile.
Here are your assignments:
ALL:  Please give your opinions of the questions below. Some are simple
questions resulting from the fact that I'm not used to ITAPS code
conventions.
Mark M. and Lori:
-  Review all functions at a high level to identify gaps and duplications in
capability.  Suggest functions that should be added or removed.
-  Review all functions at a high level to determine whether our syntax is
generally consistent with ITAPS' conventions and generally consistent within
the document.  You shouldn't catch every detail; just let us know whether
someone who is comfortable with other ITAPS interfaces would find this
interface comfortable as well.
Mark M and Onkar:
-  Review all functions at a high level and indicate whether their use of
communication will be definite, likely, or nonexistent.  If they incur
communication, will the communication be global (e.g., MPI_Allreduce) or
point-to-point (e.g., MPI_Send/MPI_Recv)?  We'll eventually modify the
function names to indicate whether or not they incur communication.
Onkar:
-  Review in detail the Entity Functionality section.  This section has the
entity copying capability, including the add/remove copies that you
discussed in the last phone conf.
Vitus:
-  Propose the communication functions needed to support
prefix_sendEntArrToParts and prefix_receiveEntArrToParts.
Carl:
-  Should functions prefix_getEntSets and prefix_getNumEntSets be added to
Carl's sixteen functions?  They appear to be analogous to
prefix_getEntities and prefix_getNumOfType.
-  Review in detail the Part Functionality section.
Tim:
-  Review in detail the Partition Functionality section.
Questions for everyone:
-  When we specify a part handle, must we always also specify a partition
handle?  That is, should a part be uniquely identified by the pair
(partition_handle, part_handle), just as entities are uniquely identified by
(mesh_instance, entity_handle)?   "No" is the most convenient answer to this
question; if parts are uniquely identified by only the part handle, we can
do the entity-set argument overloading that we discussed at bootcamp.  We
can also remove the partition_handle argument from many of the functions.  I
had previously argued for use of the tuple, but many things would be easier
if we didn't need it.  Can all the implementations generate part handles
that are unique within an iMesh_Instance, rather than within a partition?
-  With iterators over parts or part boundaries, is it necessary to have
separate interface functions for getNext, reset, and end, or will the
standard iMesh functions for getNext, reset, and end suffice?  That is, once
an iterator is initiated, do we need to continue passing the part handle
and, perhaps, neighbor-part id, to the iterator, or can the iterator
"remember" these just as it remembers entity type and topology?  If we can
re-use the iMesh getNext, reset and end, we can remove six functions from
Carl's sixteen functions, bringing the count back to his original estimate
of ten.
-  Which functions should operate on single parts and/or entities, and which
should have array versions (function_name and function_nameArr)?  I included
both wherever we had a comment "Need single-part and array-part versions" in
the combined document, but I won't be offended if we remove some of the
functions.
-  Since global IDs for entities are not used anywhere in the interface, I
propose their generation and use should be a service on top of the interface
rather than part of the interface.  What say you?
Desc: DraftInterface.h
URL: <http://lists.mcs.anl.gov/pipermail/itaps-parallel/attachments/20080122/0a2c2293/attachment.obj>
More information about the itaps-parallel mailing list
