itaps-parallel Phone conf today
Mark Shephard
shephard at scorec.rpi.edu
Tue Jan 8 09:53:52 CST 2008
Tim Tautges wrote:
> With all due respect, no, I do not intend to stop talking about the data
> model. As I have spoken about many times in talks (and not nearly
> enough in papers, I guess), the data model is extremely important to our
> project. In fact, I believe it is as important as the API. Until tools
> exchange tool-specific data in terms of the ITAPS data model we have
> chosen, we will not have true interoperability.
> I would also assert that the geometric modeling tools are a good example
> of the failure of API's to provide interoperability. Each of the
> commercial geometric modelers has its own API, but they are not
> interoperable, even after smoothing the differences between just the API
> functions with common functionality. For example, one API (ACIS, or
> Parasolids) tells you how to get bounding vertices from faces, so you
> write your application to count on that. Then, that application does
> not work on the next modeler and its API (e.g. ProToolkit), because that
> modeler doesn't provide vertices in the first place.
We have found the solid modelers API very robust and have worked well
with them.
> Another example coming up soon is our parallel interface and the
> interoperability of tools built on that interface. If that interface
> were written in terms of our existing data model, and if the iMesh and
> iGeom entity type-based functions were moved down to iBase, I could
> write a single partitioning tool that applied to both mesh and geometry
> equally well, with only a different function for determining the weights
> of nodes and edges in the graph. Same goes for visualization, boundary
> condition editing, and lots of other functions we both know are part of
> a "real" simulation process. Incidentally, that's one of the reasons I
> still advocate keeping around the SIDL interface (because that provides
> polymorphism necessary to write abstract tools like that).
I see no real point here. To me this is a matter of the API, not how I
do or do not store my data.
> - tim
> Mark Shephard wrote:
>> In yesterdays phone call we yet again went back to the discussion on
>> data model vs API. As near as I can tell iMesh, iGeom, etc. are API’s
>> where there are agreed to functions that take specific information as
>> input and provide specific information as answers to the question. For
>> example, the one we keep discussing is give me the group of mesh faces
>> that meet two conditions (one example, but only one example, of which
>> is the mesh faces in a specific part and has a specific BC). This can
>> be discussed at the API level quite independently of one does it with
>> carrying out Booleans of sets of does something else underneath to
>> provide the answer to the question.
>> The geometric modeling tools have done this well for many years
>> focused on the API end of it and no one has problems with it.
>> Since it is quite clear that different ITAPS groups have very
>> different data models for how they do thing which are actually driven
>> by valid concepts, that have also been discussed many times before,
>> can we please focus on the API level and quite telling each other we
>> have to adopt a specific data model.
>> Mark
>> Devine, Karen D. wrote:
>>> My calendar shows that we have a phone conference scheduled for today at
>>> 1:30pm PST. Please let me know if you expect to miss this meeting
>>> (or if
>>> you think my calendar is incorrect).
>>> There has been lots of good discussion since our last meeting.
>>> Please take
>>> time to review it before the phone conference.
>>> Below are topics for discussion.
>>> - Tim asked that we clarify the questions we are addressing. He
>>> listed the
>>> following:
>>> 1) Do we want to do booleans on query results below the interface
>>> level?
>>> An example query would be "What are all regions in some set in a
>>> particular part?"
>>> 2) How do we express and query sets spread across processors?
>>> 3) How do we refer to parts and partitions in the interface, and
>>> which
>>> functions do we use to get information about them?
>>> So far, our efforts have been addressing (3) and, more recently,
>>> (1). With
>>> respect to (3), we have agreed to provide helper-functions that expose
>>> partition and part information through the interface. These
>>> helper-functions are natural for an application to use and allow the
>>> greatest flexibility for the implementations. With respect to (1), we
>>> identified the need to answer queries such as the example Tim provided.
>>> Several options were proposed to answer these queries (see below). Tim
>>> noted that similar capability could be useful for intersections of
>>> multiple
>>> entity sets. We have not deeply explored question (2) yet, and
>>> unless there
>>> is a reason to do so immediately, I'd like to resolve (3) and (1)
>>> before we
>>> start into (2).
>>> - I'd like to try to reach agreement on a solution to question (1)
>>> above.
>>> Our original idea of overloading the mesh instance argument is
>>> insufficient
>>> for answering these queries, especially in a multiplexing
>>> environment. Carl
>>> summarized three options; I'd like to discuss the pros/cons of each.
>>>> a) Adding args to about 10 functions, for both serial and parallel.
>>>> Requires: universal agreement about what a null handle is, or else
>>>> definition of an implementation-specific global variable that apps can
>>>> use to find out what the null handle is for that impl. Also, for every
>>>> call, the function has to identify which args it was passed and
>>>> dispatch
>>>> accordingly (creating more functions internal to the interface,
>>>> probably, but not user-visible). Changes to serial code.
>>>> b) Leaving those 10 functions alone in serial, and adding parallel
>>>> versions. Requires: adding probably one function for each of the
>>>> originals in the parallel interface. My guess from the current
>>>> document
>>>> on parallel is that we'll be looking at >100 functions already, so this
>>>> may or may not be considered significant. Serial code left untouched.
>>>> c) Adding some magic to squish three args into one in parallel.
>>>> Requires: A function to squish (and unsquish, internally) the args;
>>>> therefore, extra effort for the app and impl for each of those 10
>>>> functions every time they're called (even in serial, probably).
>>>> Depending on how the squishing is done, risk of handle collision.
>>> - Finally, I'd like to get clarity on how decisions are made in ITAPS.
>>> When the iMesh interface was defined, for example, was unanimous
>>> agreement
>>> needed on a function before it was accepted? Or was a vote taken (as I
>>> believe CCA does)?
More information about the itaps-parallel
