itaps-parallel getting ready to download the slides
Timothy J. Tautges
tautges at mcs.anl.gov
Fri Nov 14 14:57:22 CST 2008
Sounds good. I'm just pulling in the new code in the examples (but it takes some reformatting to make it fit, so it's a bit slow going).
I'd be inclined to remove the SIDL example completely; thoughts?
- tim
----- Original Message -----
To: "Timothy J. Tautges" <tautges at mcs.anl.gov>
Cc: itaps-parallel at mcs.anl.gov
Sent: Friday, November 14, 2008 2:28:13 PM GMT -06:00 US/Canada Central
Subject: Re: itaps-parallel getting ready to download the slides
Hi Tim,
Keep working. I made some changes to the slides based on what's in the
examples directory - mostly to include root set rather than 0. I wasn't
sure what to do with the SIDL example, so I left that alone. Your
slides will be the master slides and if you could send me only those
slides that you change I can incorporate those into the presentation on
my laptop. Also go ahead and update the slides in the repository and I
will try to download later tonight or tomorrow.
Lori
Timothy J. Tautges wrote:
> Drat, I'm working on my changes to examples now...
> - tim
> From: "Lori A. Diachin" <diachin2 at llnl.gov>
> To: itaps-parallel at mcs.anl.gov
> Sent: Friday, November 14, 2008 1:39:19 PM GMT -06:00 US/Canada Central
> Subject: itaps-parallel getting ready to download the slides
> any objections? I may be able to download them later while on travel,
> but the file is rather large and I'm not going to count on it...
> I've included the changes made this morning to the HandsOn files and
> printed them out. All further changes will be on line only.
> Lori
More information about the itaps-parallel
