itaps-parallel Directory rearrangement on mesh?
Devine, Karen D
kddevin at sandia.gov
Fri Nov 14 11:59:05 CST 2008
Tim: Have you had time to update the slides with the revised examples?
Karen
On 11/14/08 10:40 AM, "Lori A. Diachin" <diachin2 at llnl.gov> wrote:
> Hi all,
> I have my concerns about major changes right now. I do like Tim's
> directory structure and I suggest we use it in the Dist directory. I
> don't think we should make major changes to /usr/local/itaps at this
> late date as I don't think we have time to test... I would much rather
> see things added to Dist and have folks do a first order pass at making
> sure they can download and build what's there. While I won't be making
> major changes to what's posted on the web site before the tutorial, if
> folks are interested we will point them to software in the Dist
> directory to download and try - it would be nice if everything there had
> been built by at least one other person as a sanity check. That said,
> all that's there now is the zoltan and fmdb stuff... can we get the
> other software there as well?
> I have a meeting now and will be back in an hour or so - I'll make the
> changes to the formated instruction pages to match what's currently in
> the directory and print around 10:30-11 am. I'm also going to download
> the slides to my laptop at that time. Unfortunately, I will be away
> from my office this afternoon, so I need to get this done before lunch.
> Lori
> Devine, Karen D wrote:
>> I really like Tim's suggested directory structure, but I am concerned that
>> if we move things now, our hand-outs and makefiles will be out-of-date. How
>> much last-minute work are we up for today? :) :)
>> Karen
>> On 11/14/08 10:09 AM, "Vitus Leung" <vjleung at sandia.gov> wrote:
>>> Tim,
>>> I see that you have made these directories. I am not completely sure
>>> what goes where. iZoltan is a service, but where should Zoltan, siMPI,
>>> ParMETIS3_1, and paraview-... go? My guess would be that Zoltan, siMPI
>>> and ParMETIS3_1 should go in services with iZoltan and paraview-...
>>> should go in apps.
>>> Vitus
>>> On Fri, 2008-11-14 at 08:43 -0700, Tim Tautges wrote:
>>>> Hi all,
>>>> How do we rearrange the disk stuff on mesh? I'm thinking we'll have
>>>> subdirectories under /usr/local/itaps:
>>>> Implementations
>>>> Services
>>>> Applications
>>>> Dist
>>>> Tutorial_Exercises
>>>> Tutorial_Notes
>>>> Anything else? Documentation?
>>>> I know we discussed this but don't remember the conclusion. I'd say
>>>> we/I should make those directories and let others move/install into them
>>>> when they're ready.
>>>> - tim
>>>> "You will keep in perfect peace him whose mind is
>>>> steadfast, because he trusts in you." Isaiah 26:3
>>>> Tim Tautges Argonne National Laboratory
>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
>>>> phone: (608) 263-8485 1500 Engineering Dr.
>>>> fax: (608) 263-4499 Madison, WI 53706
More information about the itaps-parallel
