itaps-parallel FMDB_iMeshP is updated
txie at scorec.rpi.edu
Thu Nov 13 20:40:04 CST 2008
Hi all,
We have finished the following updates to FMDB_iMeshP (as per recent
requests).
* 1. Put a tarball of FMDB_iMeshP.tgz in /usr/local/itaps/Dist/ on the
mesh machine. And put the latest FMDB_iMeshP version into the repository.
* 2. Modified iMesh_protos.h and iMeshP_protos.h files, and solve Fortran
name mangling through configure in GNU autoconf.
* 3. About the iMesh_getEnt2ndAdj() function, I suggest that we can use
"bridge_entity_type" and "requested_entity_type" both in the
specification and in the function declaration. They seems to be more
clear.
/**\brief Get "2nd order" adjacencies to an entity
* Get "2nd order" adjacencies to an entity, that is, from an entity,
through
* other entities of a specified "bridge" dimension, to other entities
of another
* specified "to" dimension.
* \param instance iMesh instance for this call
* \param entity_handle Entity from which adjacencies are requested
* \param bridge_entity_type Type of bridge entity for 2nd order adjacencies
* \param requested_entity_type Type of adjacent entities returned
* \param adjacent_entities Adjacent entities
* \param adjacent_entities_allocated Allocated size of returned array
* \param adjacent_entities_size Occupied size of returned array
* \param err
void iMesh_getEnt2ndAdj( iMesh_Instance instance,
iBase_EntityHandle entity_handle,
int bridge_entity_type,
int requested_entity_type,
iBase_EntityHandle** adjacent_entities,
int* adjacent_entities_allocated,
int* adjacent_entities_size,
int* err );
* 4. Modified and updated the iMesh-Defs.inc.in file based on Lori and
Karen's suggestions, and iMesh-Defs.inc file can be created through
autoconf.
* 5. Make sure that iMesh_load function can load *.sms and *.vtk file.
Please let us know if there are any problems (which will mostly be
considered after SC08). Also keep in mind that we are not considering any
further changes to FMDB install (and tar ball) on mesh-machine before SC08
(only typos and critical bugs are likely to be considered before SC08).
Ting (and RPI team)
More information about the itaps-parallel
