itaps-parallel VisIt Linked with Parallel FMDB
Onkar Sahni osahni at scorec.rpi.edu
Thu Nov 13 16:40:15 CST 2008
Thats good... keep us updated and in case if you need help in debugging
(and also if errors are coming from FMDB). I guess we would not be able to
resolve this before SC08 but if we do I will be happy to load a mesh in
VisIt and just project it and show that it loads.
- Onkar
> Hi Onkar,
> Some good news. I've managed to link VisIt with parallel FMDB vi iMeshP
> and open a multi-part sms file. However, when I go to plot it in VisIt,
> it is segv'ing somewhere in VisIt. So, I still have some work to do.
> However, up until now, it has been a major chore to get everything to
> link and operate correctly. VisIt's shared libraries have made it
> particularly difficult.
> Mark
> On Wed, 2008-11-12 at 16:33, Onkar Sahni wrote:
>> I think my point is being missed, here is my last attempt... if in case
>> of
>> MOAB "AC_CONFIG_HEADERS is called to produce MBCN_FCDefs.h" why not one
>> can produce "ITAPS_FCDefs.h" in a central place and one central
>> iMesh_protos.h includes ITAPS_FCDefs.h that is generated during as an
>> install/build process (all ITAPS header files can live in one location,
>> for example, /usr/local/itaps/headers).
>> In summary, user/app. would do following basic steps:
>> * Download itaps-headers (say in /<path-itaps-headers>/)
>> * Run configure to generate ITAPS_FCDefs.h in /<path-itaps-headers>/ (an
>> app./user would do this step with platform and compiler combination of
>> their choice)
>> * Download any implementation/service (such as FMDB/MOAB/GRUMMP or
>> iZoltan)
>> * Run configure and compile it (point to /<path-itaps-headers>/ to get
>> header files from central place)
>> * Write app. code like MHD solver
>> * Build it and link with appropriate libs. (ofcourse fortran name
>> mangling
>> has to be consistent while compling app. code with ITAPS_FCDefs.h
>> generated by app.)
>> Is this not possible?
>> - Onkar
>> > On Wed, 2008-11-12 at 16:53 -0500, Onkar Sahni wrote:
>> >> > The FC_FUNC macro winds up getting defined by something; Autoconf's
>> >> configure script does some work to define it. Or, like Onkar
>> suggests,
>> >> you can define some logic ahead of time to set whatever FC_FUNC does
>> >> using logic like so...
>> >> > #ifdef AIX
>> >> > #define FC_FUNC(lowFunc,UPfunc) _lowFunc
>> >> > #elif GFORTRAN
>> >> > #define FC_FUNC(lowFunc,UPfunc) UPfunc
>> >> > #elif ...
>> >>   So here is my question (basically what I was trying to ask in
>> >> tele-con)
>> >> which may or may not be possible:
>> >>   Can "#define FC_FUNC............" be generated in a central place
>> >> during
>> >> the process to install and build itaps softwares (before building any
>> > I don't think it can because its definition depends on the name
>> mangling
>> > properties of the fortran compiler being used at time of
>> (configuration)
>> > compilation. Yes, the number of possible definitions for FC_FUNC is
>> > finite, but know which it should be set to for a given compiler (and
>> > what to use in the way of a detecting that) varies from compiler to
>> > compiler. The BEST you can achieve is to identify what FC_FUNC should
>> be
>> > identified for common cases or cases that you know of so that it
>> doesn't
>> > need to be re-computed with each configure/compile.
>> >> implementation/library or service). This would be an extra configure
>> >> step in say /usr/local/itaps/headers (central location where all
>> headers
>> >> sit along with probably configure stuff) and this step would just
>> >> generate a new header file say "itaps_fc_func.h".
>> >> Say if one uses gfortran then the header file generated in "central"
>> >> place
>> >> (as an extra step using configure in "central" place) will contain
>> >> following lines and every service and implementation simply use it.
>> >>   #ifndef _ITAPS_FC_FUNC_H_
>> >>   #define _ITAPS_FC_FUNC_H_
>> >>   /* following line is for specific platform, compiler... combination
>> >>   #endif
>> >> - Onkar
>> >> > The only issue I see with this approach is that you need to have
>> >> defined
>> >> ahead of time all the possible #ifdef #elif cases above and whenever
>> you
>> >> go to a new machine, then you'll have to re-visit this logic. So, I
>> like
>> >> the approach where Autconf's configure is used to set FC_FUNC.
>> >> > Finally, whatever FC_FUNC is set to, it MUST match the actual name
>> >> mangling used by whatever fortran compiler is being used to compile
>> the
>> >> code. So, it is not just a matter of everyone agreeing on an
>> >> > implementation for FC_FUNC. FC_FUNC must also address whatever name
>> >> mangling is being used by a given fortran compiler on a given
>> platform
>> >> when the code is getting compiled. For that reason, I think the best
>> >> approach is the Autoconf approach.
>> >> > Mark
>> >> > Mark C. Miller, Lawrence Livermore National Laboratory
>> >> > email: mailto:miller86 at llnl.gov
>> >> > (M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
>> >> > (Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel mailing list
