itaps-parallel Name mangling in MOAB
Mark Miller
miller86 at llnl.gov
Thu Nov 13 13:03:27 CST 2008
Tim,
I wonder if you could leave the default to what it was and if someone
needs gcc-4.3, they use that explicitly?
On Thu, 2008-11-13 at 10:35, Tim Tautges wrote:
> Hi all,
> On the mesh machine, I've changed the symbolic links gcc, g++, and
> gfortran in /usr/bin to point to the 4.3 series gnu compilers. If you'd
> prefer to use the 4.2 series, just use gcc-4.2, etc.
> Ting, this should work for you now.
> - tim
> txie at scorec.rpi.edu wrote:
> > Hi Tim,
> > Thanks. But this file seems too long for me to understand in a short time.
> > May you create a link to gfortran in /usr/bin/, just as gcc and g++?
> > Thanks.
> > Ting
> >> In MOAB, we use an m4 macro to attempt to find compilers automatically;
> > see ~tautges/ITAPS/SVN/Examples/m4/compiler.m4 on the mesh machine. This
> > produces the F77 or FC variables, which can be over-ridden on the
> > configure line.
> >> - tim
> >>> Tim,
> >>> I add one option FC=/usr/local/gcc-4.3/bin/gfortran in the configure, and
> >>> it works now.
> >>> But may you tell me how to fix this minor problem, not by setting
> > option
> >>> in the configure? Since other people may have the same problem in the
> > tutorial, and then they will get undefined errors in compiling FMDB.
> > Thanks.
> >>> Regards,
> >>> Ting
> >>>> Tim,
> >>>> Thanks for your reply. We can test them later.
> >>>> I got another problem when I configured FMDB on mesh machine. It can not
> >>>> find Fortran compiler on mesh machine, and the IMESH_FCDefs.h file is
> > empty. here is the output from the configure. Did I miss anything in
> > configure file? I did not meet such problem on our SCOREC machine.
> > Thanks.
> >>>> appending configuration tag "F77" to libtool
> >>>> checking for gfortran... no
> >>>> checking for g95... no
> >>>> checking for xlf95... no
> >>>> checking for f95... no
> >>>> checking for fort... no
> >>>> checking for ifort... no
> >>>> checking for ifc... no
> >>>> checking for efc... no
> >>>> checking for pgf95... no
> >>>> checking for lf95... no
> >>>> checking for ftn... no
> >>>> checking for xlf90... no
> >>>> checking for f90... no
> >>>> checking for pgf90... no
> >>>> checking for pghpf... no
> >>>> checking for epcf90... no
> >>>> checking for g77... no
> >>>> checking for xlf... no
> >>>> checking for f77... no
> >>>> checking for frt... no
> >>>> checking for pgf77... no
> >>>> checking for cf77... no
> >>>> checking for fort77... no
> >>>> checking for fl32... no
> >>>> checking for af77... no
> >>>> checking whether we are using the GNU Fortran compiler... no
> >>>> Ting
> >>>>> Good question. I think the best way to test this would be to
> > configure/build both FMDB and MOAB and use 'nm' to check function
> > signatures in libiMesh.a. Even better would be to do that with
> > different compilers that mangle names differently, and make sure the
> > two
> >>>>> still agree, but that probably is too much work for now.
> >>>>> - tim
> >>>>>> Tim,
> >>>>>> Thanks for your explanations. They are very clear. I have modified FMDB
> >>>>>> like that. But I do not know how to test and use this, and also the
> > iMesh-Defs.inc file. May you let me know how to test them if you
> > have
> >>>>>> time? Thanks.
> >>>>>> Regards,
> >>>>>> Ting
> >>>>>>> You bet. If you have any trouble, just send me or Jason email. - tim
> >>>>>>>> Tim,
> >>>>>>>> Thanks a lot.
> >>>>>>>> Ting
> >>>>>>>>> Hi all,
> >>>>>>>>> See
> >>>>>>>>> http:// trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/configure.in,
> > lines 31-33. If the script finds a fortran compiler, it runs
> > that
> >>>>>>>>> macro. That generates definitions for FC_FUNC and FC_FUNC_. Then,
> >>>>>>>>> at
> >>>>>>>>> line 869 in configure.in, AC_CONFIG_HEADERS is called to produce
> > MBCN_FCDefs.h, which contains substituted definitions for FC_FUNC
> > and
> >>>>>>>>> FC_FUNC_. Those macros are used in iMesh_protos.h
> >>>>>>>>> (http:// trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/tools/iMesh/iMesh_protos.h)
> > to mangle the imesh function names.
> >>>>>>>>> If you're doing this in FMDB, it's probably easier to eliminate
> > going
> >>>>>>>>> through MBCN_FCDefs.h or equivalent and call AC_CONFIG_HEADERS
> > directly
> >>>>>>>>> on iMesh.h, though you'll have to make a iMesh.h.in file for that to
> >>>>>>>>> work properly.
> >>>>>>>>> Any questions, let me know.
> >>>>>>>>> - tim
> > "You will keep in perfect peace him whose mind is
> >>>>>>>>> steadfast, because he trusts in you." Isaiah
> > 26:3
> >>>>>>>>> Tim Tautges Argonne National Laboratory
> >>>>>>>>> (tautges at mcs.anl.gov) (telecommuting from
> >>>>>>>>> UW-Madison)
> >>>>>>>>> phone: (608) 263-8485 1500 Engineering Dr.
> >>>>>>>>> fax: (608) 263-4499 Madison, WI 53706
> >>>>>>> steadfast, because he trusts in you." Isaiah 26:3
> > UW-Madison)
> >>>>> ================================================================ "You
> >>>>> (tautges at mcs.anl.gov) (telecommuting from UW-Madison)
Mark C. Miller, Lawrence Livermore National Laboratory
email: mailto:miller86 at llnl.gov
(M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
(Th/F) (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel
