itaps-parallel Makefiles in tutorial exercises
Vitus Leung
vjleung at sandia.gov
Thu Nov 13 13:02:50 CST 2008
There are some typos in that file.
Vitus
On Thu, 2008-11-13 at 11:30 -0700, Lori A. Diachin wrote:
> While you're making last minute changes to your exercises, I'd like to
> advocate that if you haven't already done so you use the iMesh-Defs.inc
> file that is now available in /usr/local/itaps/FMDB_iMeshP/lib. This
> is consistent with the process we would like to encourage folks to use
> in their makefiles, so our examples should use it as well. The
> variables are defined below. I thought that we had only defined
> IMESH_INCLUDES, IMESH_LIBS, etc... is there a potential problem with
> possible conflicts in the FLAGS definitions?
> here's the iMesh-Defs.inc file from FMDB
> IMESH_CXXFLAGS = -g -O2
> IMESH_CFLAGS = -g -O2
> IMESH_LDFLAGS =
> IMESH_CXX_LDFLAGS =
> IMESH_CXX_LIBS =
> IMESH_INCLUDES = -I$(IMESH_INCLUDEDIR)/include/FMDB
> -I$(IMESH_INCLUDEDIR)/include/SCORECModel
> -I$(IMESH_INCLUDEDIR)/include/SCORECUtil
> IMESH_LIBS = -L$(FMDB_IMESH_LIBDIR) -lFMDB -lSCORECModel -lSCORECUtil \
> -L$(FMDB_IMESH_LIBDIR)/share/lib/$linux64 -lautopack
> IMESH_INCLUDEDIR = /usr/local/itaps/FMDB_iMeshP/
> FMDB_IMESH_LIBDIR = /usr/local/itaps/FMDB_iMeshP/
> iMesh_INCLUDEDIR=/usr/local/itaps/FMDB_iMeshP//include
> FMDB_iMesh_LIBDIR=/usr/local/itaps/FMDB_iMeshP//lib
More information about the itaps-parallel
