itaps-parallel Makefiles in tutorial exercises
Lori A. Diachin
diachin2 at llnl.gov
Thu Nov 13 12:30:57 CST 2008
While you're making last minute changes to your exercises, I'd like to
advocate that if you haven't already done so you use the iMesh-Defs.inc
file that is now available in /usr/local/itaps/FMDB_iMeshP/lib. This
is consistent with the process we would like to encourage folks to use
in their makefiles, so our examples should use it as well. The
variables are defined below. I thought that we had only defined
IMESH_INCLUDES, IMESH_LIBS, etc... is there a potential problem with
possible conflicts in the FLAGS definitions?
here's the iMesh-Defs.inc file from FMDB
IMESH_CXXFLAGS = -g -O2
IMESH_CFLAGS = -g -O2
IMESH_LDFLAGS =
IMESH_CXX_LDFLAGS =
IMESH_CXX_LIBS =
IMESH_INCLUDES = -I$(IMESH_INCLUDEDIR)/include/FMDB
-I$(IMESH_INCLUDEDIR)/include/SCORECModel
-I$(IMESH_INCLUDEDIR)/include/SCORECUtil
IMESH_LIBS = -L$(FMDB_IMESH_LIBDIR) -lFMDB -lSCORECModel -lSCORECUtil \
-L$(FMDB_IMESH_LIBDIR)/share/lib/$linux64 -lautopack
IMESH_INCLUDEDIR = /usr/local/itaps/FMDB_iMeshP/
FMDB_IMESH_LIBDIR = /usr/local/itaps/FMDB_iMeshP/
iMesh_INCLUDEDIR=/usr/local/itaps/FMDB_iMeshP//include
FMDB_iMesh_LIBDIR=/usr/local/itaps/FMDB_iMeshP//lib
More information about the itaps-parallel
