itaps-parallel Hands-on notes
Devine, Karen D kddevin at sandia.gov
Thu Nov 13 11:29:25 CST 2008
To hands-on example developers:
The HandsOn notes need to be updated to reflect our new directory structure.
Most of the notes started with a copy of the exercise to the user's home
directory.  The path for this copy has changed.  To make things easier, I
instructed the students to copy the entire Tutorial_Exercises directory to
their home directories.  So each HandsOn session should begin with something
like
  cd ~/Tutorial_Exercises/2_Load_Balance
(Note that the directory names for the individual directories has also
changed.)
Also, if you started with my notes, the path to the documentation directory
has to be updated.  The old path was Hello/DOCUMENTS; the new path is
Tutorial_Exercises/ITAPS_DOCS or the web page
http://www.itaps.org/software/download_interfaces.html.
I am willing to make these updates for everyone, but I hesitate to edit the
files without your permission (in case you are also editing them elsewhere).
If you want me to change them, let me know.  If you make the changes
yourself, please remember to work in Tutorial_Examples/your_example rather
than your previous directory.
You should probably also delete your previous examples directory in
/usr/local/itaps so that the directory looks neater.
Karen
More information about the itaps-parallel mailing list
