itaps-parallel Fortran name mangling issues
Tim Tautges tautges at mcs.anl.gov
Thu Nov 13 11:16:13 CST 2008
Onkar Sahni wrote:
> Thanks Tim for looking into it and Thanks Mark M. for brining this issue
> in an organized way.
> There are two further suggestions I want to mention:
> a) If possible, we keep both options available (one where there is a
> central place for headers and FCdefs, and other what we do now) or some
> blend of it, so that user can choose.
I am in full support of this.
- tim
> b) We let some (selected) users try either one solution and get their
> feedback, and go with one option accordingly.
> Thanks,
> Onkar
>> Onkar,
>>    I understand your suggested solution, and agree that it would work.
>> I just don't think it's the best one when you consider all the use
>> cases.  The advantage of your approach is that you're guaranteed to have
>> all implementations/services agreeing on the name mangling and function
>> signatures.  The disadvantage is that services and apps require an
>> extra, independent process to build part of their iMesh-dependent code.
>>   While this extra step isn't that difficult, it presents an extra
>> burden on users and on service/impl'n developers.  Furthermore, there's
>> an alternative solution that buys us almost the same thing while
>> preserving independence.  The disadvantage of this alternative solution
>> is something controlled by us and can be minimized.
>> - tim
>> Onkar Sahni wrote:
>>> I think my point is being missed, here is my last attempt... if in case
>>> of
>>> MOAB "AC_CONFIG_HEADERS is called to produce MBCN_FCDefs.h" why not one
>>> can produce "ITAPS_FCDefs.h" in a central place and one central
>>> iMesh_protos.h includes ITAPS_FCDefs.h that is generated during as an
>>> install/build process (all ITAPS header files can live in one location,
>>> for example, /usr/local/itaps/headers).
>>> In summary, user/app. would do following basic steps:
>>> * Download itaps-headers (say in /<path-itaps-headers>/)
>>> * Run configure to generate ITAPS_FCDefs.h in /<path-itaps-headers>/ (an
>>> app./user would do this step with platform and compiler combination of
>>> their choice)
>>> * Download any implementation/service (such as FMDB/MOAB/GRUMMP or
>>> iZoltan)
>>> * Run configure and compile it (point to /<path-itaps-headers>/ to get
>>> header files from central place)
>>> * Write app. code like MHD solver
>>> * Build it and link with appropriate libs. (ofcourse fortran name
>>> mangling
>>> has to be consistent while compling app. code with ITAPS_FCDefs.h
>>> generated by app.)
>>> Is this not possible?
>>> - Onkar
>>>> On Wed, 2008-11-12 at 16:53 -0500, Onkar Sahni wrote:
>>>>>> The FC_FUNC macro winds up getting defined by something; Autoconf's
>>>>> configure script does some work to define it. Or, like Onkar suggests,
>>>>> you can define some logic ahead of time to set whatever FC_FUNC does
>>>>> using logic like so...
>>>>>> #ifdef AIX
>>>>>> #define FC_FUNC(lowFunc,UPfunc) _lowFunc
>>>>>> #elif GFORTRAN
>>>>>> #define FC_FUNC(lowFunc,UPfunc) UPfunc
>>>>>> #elif ...
>>>>>   So here is my question (basically what I was trying to ask in
>>>>> tele-con)
>>>>> which may or may not be possible:
>>>>>   Can "#define FC_FUNC............" be generated in a central place
>>>>> during
>>>>> the process to install and build itaps softwares (before building any
>>>> I don't think it can because its definition depends on the name
>>>> mangling
>>>> properties of the fortran compiler being used at time of
>>>> (configuration)
>>>> compilation. Yes, the number of possible definitions for FC_FUNC is
>>>> finite, but know which it should be set to for a given compiler (and
>>>> what to use in the way of a detecting that) varies from compiler to
>>>> compiler. The BEST you can achieve is to identify what FC_FUNC should
>>>> be
>>>> identified for common cases or cases that you know of so that it
>>>> doesn't
>>>> need to be re-computed with each configure/compile.
>>>>> implementation/library or service). This would be an extra configure
>>>>> step in say /usr/local/itaps/headers (central location where all
>>>>> headers
>>>>> sit along with probably configure stuff) and this step would just
>>>>> generate a new header file say "itaps_fc_func.h".
>>>>> Say if one uses gfortran then the header file generated in "central"
>>>>> place
>>>>> (as an extra step using configure in "central" place) will contain
>>>>> following lines and every service and implementation simply use it.
>>>>>   #ifndef _ITAPS_FC_FUNC_H_
>>>>>   #define _ITAPS_FC_FUNC_H_
>>>>>   /* following line is for specific platform, compiler... combination
>>>>>   #endif
>>>>> - Onkar
>>>>>> The only issue I see with this approach is that you need to have
>>>>> defined
>>>>> ahead of time all the possible #ifdef #elif cases above and whenever
>>>>> you
>>>>> go to a new machine, then you'll have to re-visit this logic. So, I
>>>>> like
>>>>> the approach where Autconf's configure is used to set FC_FUNC.
>>>>>> Finally, whatever FC_FUNC is set to, it MUST match the actual name
>>>>> mangling used by whatever fortran compiler is being used to compile
>>>>> the
>>>>> code. So, it is not just a matter of everyone agreeing on an
>>>>>> implementation for FC_FUNC. FC_FUNC must also address whatever name
>>>>> mangling is being used by a given fortran compiler on a given platform
>>>>> when the code is getting compiled. For that reason, I think the best
>>>>> approach is the Autoconf approach.
>>>>>> Mark
>>>>>> Mark C. Miller, Lawrence Livermore National Laboratory
>>>>>> email: mailto:miller86 at llnl.gov
>>>>>> (M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
>>>>>> (Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
>> "You will keep in perfect peace him whose mind is
>>    steadfast, because he trusts in you."               Isaiah 26:3
>>               Tim Tautges            Argonne National Laboratory
>>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>>           phone: (608) 263-8485      1500 Engineering Dr.
>>             fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
