itaps-parallel Name mangling in MOAB
Tim Tautges tautges at mcs.anl.gov
Wed Nov 12 15:29:14 CST 2008
Hi all,
   See
http://trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/configure.in,
lines 31-33.  If the script finds a fortran compiler, it runs that
macro.  That generates definitions for FC_FUNC and FC_FUNC_.  Then, at
line 869 in configure.in, AC_CONFIG_HEADERS is called to produce
MBCN_FCDefs.h, which contains substituted definitions for FC_FUNC and
FC_FUNC_.  Those macros are used in iMesh_protos.h
(http://trac.mcs.anl.gov/projects/ITAPS/browser/MOAB/trunk/tools/iMesh/iMesh_protos.h)
to mangle the imesh function names.
If you're doing this in FMDB, it's probably easier to eliminate going
through MBCN_FCDefs.h or equivalent and call AC_CONFIG_HEADERS directly
on iMesh.h, though you'll have to make a iMesh.h.in file for that to
work properly.
Any questions, let me know.
- tim
   steadfast, because he trusts in you."               Isaiah 26:3
              Tim Tautges            Argonne National Laboratory
          (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
          phone: (608) 263-8485      1500 Engineering Dr.
            fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
