itaps-parallel Tutorial Exercises Directory
Mark Miller miller86 at llnl.gov
Wed Nov 12 13:18:45 CST 2008
Oops, that should be...
chmod -R u+rwX,g+rwX,o+rX *
Note the cap X means set executable whenever that is appropriate.
On Wed, 2008-11-12 at 11:10 -0800, Mark Miller wrote:
> Hi Lori,
> This will change everything below . to group read/write and
> Execute where appropriate...
> chgrp -R itaps *
> chmod -R u+rwX,g+rwX,o+r *
> Mark
> On Wed, 2008-11-12 at 11:55 -0700, Devine, Karen D wrote:
> > Lori:
> > Can you change the ownership of the files and directories in
> > Tutorial_Exercises so that the original developer can edit them?
> >   chown -R kddevin 1_Hello
> > Thanks.
> > Karen
> > On 11/12/08 11:45 AM, "Lori A. Diachin" <diachin2 at llnl.gov> wrote:
> > > Hi All,
> > > I created a first pass of the Tutorial_Exercises directory in
> > > /usr/local/itaps on the mesh machine.  I give a recommended order of
> > > performing the exercises and a brief description of each in the README.
> > > Please take a quick look, and if there are any issues we can correct
> > > them during the telecon.
> > > Tim,  I'd like to add the Examples directory you're working on to this
> > > as well.  We should talk about the best way to do that... can you create
> > > a HandsOn_Session.txt file to walk folks through what's in the
> > > directory, how to use it, and what libraries to link to?
> > > Finally - during the telecon, I'd like to revisit the notion of
> > > providing directions for folks to download and build an iMesh
> > > implementation on their own machine as part of the HandsOn directory.
> > > Will this be possible to achieve?
> > > Karen - you and I probably need to spend a few minutes on the phone this
> > > afternoon (or soon) to update the web pages with the new documentation
> > > for iMeshP.   Also, were the issues with the iMesh doxy file resolved?
> > > BTW - I think I fixed the problem with the menuing system on the web
> > > itaps web pages (turns out internet explorer is pretty fragile when it
> > > comes to using stylesheets).  If you still have problems with it, let me
> > > know.
> > > Lori
Mark C. Miller, Lawrence Livermore National Laboratory
email: mailto:miller86 at llnl.gov
(M/T/W) (925)-423-5901 (!!LLNL BUSINESS ONLY!!)
(Th/F)  (530)-753-8511 (!!LLNL BUSINESS ONLY!!)
More information about the itaps-parallel mailing list
