itaps-parallel Notes from tutorial exercises
Onkar Sahni osahni at scorec.rpi.edu
Tue Nov 11 18:33:09 CST 2008
As per my experience, typically if an implementation supports the
functionality as per the specifications, allowing Fortran interface
support is a question of appropriate symbol definition for various
machines.
This is another reason that such things (header files) should come from a
central place like ITAPS repository and not from each specific
implementation.
Onkar
> Yep, I'll do that.  Note to others, we "ratified" the move to the
> C-based interface based in part on it working out of the box from
> Fortran.  That does take extra work to achieve due to the underscore
> handling differences on various machines.  I think it will look very bad
> if only one of our interface implementations supports Fortran (like it
> or not, there are MANY scidac apps implemented in that language, maybe
> even more than half of them).
> - tim
> Devine, Karen D wrote:
>> Tim:
>> Do you have time to build and run your example programs (FindAdj,
>> List&Sets,
>> etc.) that are in the tutorial slides?  In response to Lori's question,
>> I
>> tried to build the F77 FindAdjacency example, but I didn't succeed.  I
>> couldn't find F77 include files in FMDB.  I tried using MOAB, but cray
>> pointers in the example appear to be 32-bit while the MOAB libraries
>> that
>> are installed are 64-bit.  I don't know enough about cray pointers and
>> fortran to resolve the problem.  Even if I had gotten everything
>> compiled, I
>> didn't have an appropriate input file for testing.
>> It would be a good sanity test for us to make sure our examples in the
>> slides compile and run correctly.  We could have a separate directory
>> for
>> them in /usr/local/itaps.
>> If I had a working example to use, I think I could convert
>> hello_iMeshP.c to
>> hello_iMeshP.F.
>> Also, the FindAdj example in the slides has the root_set == 0 assumption
>> in
>> at least the C and F77 versions.
>> Thanks!
>> Karen
>> On 11/11/08 11:02 AM, "Lori A. Diachin" <diachin2 at llnl.gov> wrote:
>>> Hi Vitus and all,
>>> I went through both tutorials this morning and overall think they're
>>> quite nice.  I like that you provide the basics here in the second
>>> exercise - it's a very nice bridge between Hello and Smooth.  I have a
>>> few minor notes (below).
>>> As a general comment to everyone - do we have any tutorial exercises
>>> that aren't in C++?  I've gone through Hello, Load Balance and Smooth
>>> so
>>> far and I'm worried we'll give folks the wrong impression..   I see a
>>> .c
>>> file in the Hello directory -- would it be hard to add a fortran hello
>>> example?
>>> Lori
>>> Tutorial 1:
>>> Exercise 2: It's not clear to me where the MPI communicator is
>>> initialized in the test file?  I assume it's COMM_WORLD, but you refer
>>> to 'initialized above' and I don't see it.  I assume it's in the Init
>>> function, but it might be helpful to make it more explicit
>>> Exercise 3: Remind users how to get a string length; not all users will
>>> be c++ savy.
>>> In general it's not always clear to me why I'm doing something, getting
>>> the parts, getting various handles, etc - is it needed for Zoltan?  If
>>> you can, it would be useful to add a sentence to the beginning of each
>>> exercise giving a bit of motivation for why I need to call this
>>> function.  It will help folks think through it themselves later..
>>> Tutorial 2:
>>> Might prefer to have different test file names in tutorial 1 and
>>> tutorial 2.... Actually, rather than switching files/directories, you
>>> could keep them all part of a single tutorial and just use the #define
>>> trick that Karen used in Hello.
>>> Is .vtu a vtk format?  I'm not familiar with it and was surprised to
>>> see
>>> .vtu's... you might want to comment on what to expect in the notes for
>>> Exercise 1
> "You will keep in perfect peace him whose mind is
>    steadfast, because he trusts in you."               Isaiah 26:3
>               Tim Tautges            Argonne National Laboratory
>           (tautges at mcs.anl.gov)      (telecommuting from UW-Madison)
>           phone: (608) 263-8485      1500 Engineering Dr.
>             fax: (608) 263-4499      Madison, WI 53706
More information about the itaps-parallel mailing list
