itaps-parallel FronTier 2D tutorial in /usr/local/itaps/FronTier_tutorial
Xiaolin Li
linli at ams.sunysb.edu
Mon Nov 10 11:41:21 CST 2008
Ryan, please drop by. I had no problem with the 3D case using my code.
Something is wrong with your code.
Xiaolin
On Mon, 2008-11-10 at 10:21 -0700, Devine, Karen D wrote:
> Ryan: I forgot to say that I had no problems building or running. Also, I
> like that you used the entiity iterator. That's a nice difference from our
> other examples.
> Karen
> On 11/7/08 8:24 PM, "Ryan Kaufman" <rykauf at gmail.com> wrote:
> > I have moved the FronTier tutorial code to
> > /usr/local/itaps/FronTier_tutorial. Perhaps someone can try it out?
> > I did something neat using iterators in a for loop.
> > I copied part of the README from martin. Hope that's OK. I might make
> > small changes or tweaks this weekend, but I think it's ready.
> > I will try to post a 3D example as well, but that depends on 3d
> > actually working.
> > ~Ryan Kaufman
More information about the itaps-parallel
