itaps-parallel FronTier 2D tutorial in /usr/local/itaps/FronTier_tutorial
Devine, Karen D
kddevin at sandia.gov
Mon Nov 10 11:19:44 CST 2008
Hi, Ryan. I'm trying to work through the Frontier example, but I've run
into two problems.
- In the second EXERCISE from the top of the file, you say the FUNCTION TO
USE to get a tag handle is iMesh_getEntities(). Should it be
iMesh_createTag? Also, it isn't clear what the tag_size or tag_type of the
tag should be. You should say what will be stored in it. (I guessed
2*sizeof(double) and iBase_DOUBLE -- I guess I should have done
2*sizeof(iBase_DOUBLE) to be safe.)
- I'm trying to visualize the results. Many directories intfc-vtk.ts*
were generated, but the intfc-visit file you mention in the instructions is
not in my directory. Thus, I'm not sure how I should proceed with the
visualization.
Karen
On 11/7/08 8:24 PM, "Ryan Kaufman" <rykauf at gmail.com> wrote:
> I have moved the FronTier tutorial code to
> /usr/local/itaps/FronTier_tutorial. Perhaps someone can try it out?
> I did something neat using iterators in a for loop.
> I copied part of the README from martin. Hope that's OK. I might make
> small changes or tweaks this weekend, but I think it's ready.
> I will try to post a 3D example as well, but that depends on 3d
> actually working.
> ~Ryan Kaufman
More information about the itaps-parallel
