itaps-parallel Doxygen for iMesh.h
Devine, Karen D kddevin at sandia.gov
Fri Nov 7 15:31:48 CST 2008
Doxygen reports the following errors for iMesh.h; who is responsible for
upkeep on that interface?
Thanks.
Karen
Generating docs for file
/Users/kddevin/ITAPS/Documents/TSTT/Interface/iMeshP/iMesh.h...
/Users/kddevin/ITAPS/Documents/TSTT/Interface/iMeshP/iMesh.h:1955: Warning:
argument 'bridge_dimension' of command @param is not found in the argument
list of iMesh_getEnt2ndAdj(iMesh_Instance instance, iBase_EntityHandle
entity_handle, int order_adjacent_key, int requested_entity_type,
iBase_EntityHandle **adjacent_entities, int *adjacent_entities_allocated,
int *adjacent_entities_size, int *err)
argument 'to_dimension' of command @param is not found in the argument list
The following parameters of iMesh_getEnt2ndAdj(iMesh_Instance instance,
iBase_EntityHandle entity_handle, int order_adjacent_key, int
requested_entity_type, iBase_EntityHandle **adjacent_entities, int
*adjacent_entities_allocated, int *adjacent_entities_size, int *err) are not
documented:
  parameter 'order_adjacent_key'
  parameter 'requested_entity_type'
/Users/kddevin/ITAPS/Documents/TSTT/Interface/iMeshP/iMesh.h:665: Warning:
list of iMesh_getEntArr2ndAdj(iMesh_Instance instance, iBase_EntityHandle
const *entity_handles, int entity_handles_size, int order_adjacent_key, int
requested_entity_type, iBase_EntityHandle **adj_entity_handles, int
*adj_entity_handles_allocated, int *adj_entity_handles_size, int **offset,
int *offset_allocated, int *offset_size, int *err)
of iMesh_getEntArr2ndAdj(iMesh_Instance instance, iBase_EntityHandle const
The following parameters of iMesh_getEntArr2ndAdj(iMesh_Instance instance,
iBase_EntityHandle const *entity_handles, int entity_handles_size, int
order_adjacent_key, int requested_entity_type, iBase_EntityHandle
**adj_entity_handles, int *adj_entity_handles_allocated, int
*adj_entity_handles_size, int **offset, int *offset_allocated, int
*offset_size, int *err) are not documented:
More information about the itaps-parallel mailing list
